Charge on Capacitor: Where Does the Extra Go?
  • Thread starter Thread starter phantom113
    Capacitor Charge
When extra charge is added to one plate of a parallel-plate capacitor, it induces an equal but opposite charge on the adjacent plate, while the total charge on the opposite plate adjusts accordingly. The extra charge does not physically move across the gap between the plates, as charge cannot jump that distance. The discussion raises questions about the source of the extra charge and the connections of the plates. Ultimately, the extra charge remains on the plate, inducing changes in the electric field and charge distribution on the opposite plate. Understanding these principles is essential for grasping capacitor behavior in circuits.
phantom113
If you put more charge on one plate of a parallel-plate capacitor than on the other, where does the extra charge go?
Does the extra charge induce the same amount of opposite charge on the near side of the plate and therefore the same amount of same charge on the far side of the opposite plate? Or does the extra charge actually move somewhere?
uhh? :confused: charge can't jump the gap, so if you "put" it there, it just stays there
i don't really understand the rest of the question …
what's producing the extra charge? …
what is either plate connected to? …
was that the complete question?
That was the complete question. I figure there is nowhere for it to go so here is what I am thinking: if the initial charge on the top plate was Q and the initial charge on the bottom plate was -Q then after the charge is added the charge on the top plate is Q+S and that induces a charge of +S on the bottom of the bottom plate and a charge of -(Q+S) on the top of the bottom plate. Is that correct?
