Charging a Battery: Finding the Current in a Series Circuit
  • Thread starter Thread starter moo5003
    Battery Charging
To find the charging current in a series circuit involving a 12.0 V battery with an internal resistance of 0.02 Ohms and a battery with an emf of 10.5 V and an internal resistance of 0.15 Ohms, the setup involves determining the current flow direction and applying Kirchhoff's loop rule. The equation derived is based on the principle that the total voltage in the loop equals zero, leading to the formula I = (E2 - E1) / -(r1 + r2). The calculated current is 8.8 A, confirming the setup and calculations are correct. The discussion emphasizes the importance of understanding current direction and proper loop analysis in circuit problems. Overall, the method outlined effectively addresses the charging current calculation in this series circuit scenario.
moo5003
Problem:
"A 12.0 V battery with an internal resistance of .02 Ohms is used to charge a battery with an emf of10.5 V and an internal resistance of .15 Ohms. What is the charging current?"
Question:
I'm pretty much stuck on the set up of this problem. I know how to find the current if there was some resistor and these were hooked up in parrallel, but the way the problem is worded it makes me think these are simply just in their own loop. More over I'm not sure how I would set this problem up if they just created their own loop... Any help would be appreciated.
PS: To charge a battery the current across the battery points from negative to positive right?
Start by drawing this as one loop, yes.
Determine a direction for current flow, so start with the 12 V battery and determine initial direction for current, by convention.
Alright, I have set the problem up. I have the first battery on the left side with the current moving up and then right (From the positive) to the second battery on the right side where the current moves down through the internal resister into the negative side of the second battery which then wraps around to the internal resister of the 1st battery.
I'm assuming I use V=IR.
Please correct me if I do any of the following incorrectly:
Alrighty:
Loop: -Ir1 + E1 - E2 - Ir2 = 0
I = (E2 - E1) / -(r1+r2)
I = 8.8 A
Would this be the correct way of doing this?
Whoa...
WHen we do loops, we mean that the total voltage is zero.. O_o
so it be something like..
0 = IR + Voltage(battery) - ...
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
