Charging and Discharging of a capacitor in an LC circuit
The discussion revolves around the charging and discharging behavior of capacitors in an LC circuit, exploring the dynamics of current and voltage, energy transfer between the capacitor and inductor, and the implications of back electromotive force (emf). Participants delve into theoretical aspects, analogies, and mathematical relationships, while also addressing misconceptions and clarifying concepts.
  • Some participants propose that when a capacitor discharges through an inductor, the current initially increases despite the charge depleting, leading to questions about energy storage in the inductor when the current is zero.
  • Others argue that the inductor maintains a magnetic field even when the capacitor is fully discharged, with the current at its maximum, and that this current can recharge the capacitor with opposite polarity.
  • There is a discussion about the oscillatory nature of LC circuits, where energy oscillates between the inductor and capacitor, and how resistance affects the oscillation over time.
  • Some participants express confusion about the relationship between charge depleting from the capacitor and the behavior of current, questioning how current can peak when charge is low.
  • Others clarify that the inductor drives the current once the capacitor's charge begins to deplete, and that the back emf generated by the inductor opposes changes in current.
  • Participants explore analogies, such as comparing the system to a mass-spring model, to help visualize the energy transfer and current dynamics.
  • There are inquiries about the mathematical description of current behavior in LC circuits compared to RC circuits, with some noting that exponential decay is characteristic of RC circuits rather than LC circuits.
Participants express various viewpoints regarding the behavior of current and charge in LC circuits, with no consensus reached on several key aspects, particularly regarding the relationship between charge depletion and current behavior.
Some limitations in understanding arise from the complexity of the interactions between current, charge, and back emf in the circuit, as well as the mathematical descriptions that govern these behaviors. The discussion reflects a range of assumptions and interpretations that are not fully resolved.
This discussion may be useful for students and enthusiasts of electrical engineering, physics, and related fields who are interested in the dynamics of LC circuits and the principles of energy transfer between capacitors and inductors.
  • #31
So, initially, there is very high back emf. Then, the current is increasing but, the rate of increase of current is decreasing and hence the back emf keeps decreasing. So the capacitor potential does lesser work on a charge moving across the inductor as the work it does on the previous one.
  • #32
Thank you jbriggs444. How we prove the fact that back emf is propotional to the charge remaining on the capacitor?
  • #33
Is it that applying Faraday's Law on the circuit, we get q/C = -Ldi/dt (where q is the charge on the capacitor)= Back EMF. I guess the propotionality can be understood here. So is it right to believe that the back emf at any instant is equal to the voltage across the capacitor.
  • #34
Nikhil Rajagopalan said:
the only reason I see for current to be increasing is because the current was initially zero
That isn’t how inductors work. The current increases because the voltage is positive. That is what inductance means.
Any change in current is opposed by the inductor.
I never liked this phrasing. An inductor establishes a proportionality between voltage and change in current. If there is a voltage it makes current change, if the current changes it makes a voltage.
1.How does the current increase from there after.
As long as the voltage is positive the current will increase.
How does the maximum value of current correspond to a situation where there is hardly any charge on the capacitor
A maximum is where a function stops increasing and starts decreasing, so the maximum current is when the current stops increasing and starts decreasing. Since an inductor makes current increase in response to a positive voltage and decrease in response to a negative voltage the maximum current will necessarily be when the voltage goes from positive to negative. This is when the charge on the capacitor goes through zero.
and then it has to decrease defenitely because the charge on the capacitor is depleting.
No, this is not relevant. There is nothing about depleting the charge on a capacitor that limits the current.
  • #35
Thank you very much Dale. Does the fact that current increases for a positive voltage correspond to a no resistance situation only. That the charge carriers are accelerated. Because if there is resistance, the shouldn't the current settle down to a constant value - V/R.
  • #36
I have seen simulators showing steady increase in current when a pure inductor is connected across a DC source. and I guess i could mathematically prove that di/dt there is a constant that is equal to V/L that implies linear growth in current.
  • #37
If there is any resistance at all the current will settle down to a final value of zero. Check out the wikipedia entry on the RLC circuit and pay particular attention to the three cases for damping (underdamped, critically damped, and overdamped).
  • #38
So is this fair to put it this way.
When a fully charged capacitor is connected to an inductor, It is just like connecting a potential source to an inductor except for the fact that the capacitor as a power source has a potential difference which is propotional to the charge it holds and this potential source will have a reduce in its potential difference as it keeps dicharging.
To begin with, the fully charged capacitor at its highest potential difference causes a high increase in current from zero. as this current flows, the capacitor is in fact discharging, which means the potential difference is getting lesser. This in turn means that the rate of increase in current is going to be lesser (q/c gets lesser) and thus the increase in current decreases until there is no charge left in the capacitor. This is the time where the current in the circuit has reached its maximum owing to successive increments with decreasing magnitude(since potential difference across the capacitor was continuously decreasing).
  • #39
Make that "rate of increase". The current will follow a sine curve, starting at zero and heading towards a maximum. If you look at a sine curve you can tell the "rate of increase" by the slope of the curve as time progresses.
EDIT: You can get all of this graphically if you'd plot the capacitor voltage and circuit current on the same graph. Math can be visualized through graphs.
  • #40
Thank you gniell, I understand that. it should be high increase in unit time or rate of increase.
  • #41
I believe I have an understanding that I can work on. gniell, Dale, jgbriggs444, anorlunda, I cannot thank you enough for your precious time you took out for me. You taught me a lot of physics and a lot of values that anyone who works in education should have. I couldn't thank you enough for the help. The light you gave me shall be shared the same way.
  • #42
Here's another graphical summary of what is going on. It doesn't include the fancy energy curves that @anorlunda 's plot had, but hey, apparently I'm far more lazy than he is :smile:
Done with Mathcad: (See: lazy!)
  • #43
The current will increase any time that there is a voltage across the inductor. In a RLC circuit some of the voltage will go across the resistor, so you will have a lower rate of increase.
  • #44
Thank you so much gniell, the way you helped me, you have earned lazy rights for the rest of your life. I can understand how the LC oscillator works. It was mostly not being able to understand how a potential difference across a pure inductor works in contrast with a resistor.
  • #45
In the presence of a resistor, for damping to happen, something should cut into the current in every cycle so that it eventually dies out. When i wrote down the equation it becomes di/dt = (q/LC) - iR , so the rate of increase is reduced by the potential drop and the discharging. How does it not just result in the flattening of the curve but also reduction in amplitude.
  • #46
The resistor is dissipating energy (as heat). The current and voltage amplitudes are measures of the energy stored in the circuit in the magnetic field of the inductor and electric field of the capacitor. Dissipate the energy and you reduce the amplitudes.
  • #47
Thank you gniell. I understand the idea of the energy dissipation. I am trying to understand how the damping can be thought of graphically. The peak values of two half cycles in a damped oscillation should be asymetric, the later being smaller than the former. How does that continuous decrease in peak with every half cycle fit with the equation di/dt = (q/LC) - iR . Defenitely, di/dt will be a lesser value due to the presence of the term iR. But wouldn't that still be symmetric. with two half cycles.
  • #48
Is it because, a lesser I max cannot store as much charge in the capacitor as it used to have. making the next charging quarter cycle less taller and this continues.
  • #49
Your equation doesn't look right to me. It should be second order. Can you show how you got it? You can't mix I and Q as separate variables in the same equation when I = dQ/dt. So at the very least your dI/dt should become ##d^2 Q/dt^2##.
Solve the differential equation and you will be able to see, graphically by plotting the resulting expressions for the charge or current as a function of time, how it goes.
I encourage you to look at the math on the Wikipedia page where the effect of damping is presented in detail. They also have a graph shoing the effect of damping.
  • #50
The equation I tried was from applying Faraday's Law to the LCR circuit.
i - Current in the circuit.
Q - Maximum charge in capacitor
q - Charge in the capacitor at any instant
i = d/dt (Q-q)
According to Faraday's Law, iR - q/C = Einduced
iR - q/C = -Ldi/dt
Ldi/dt = q/C - iR
  • #51
The barrier i find in understanding it is in any case of capacitor discharging, the current is suppoused to decrease,
Why is it "supposed to decrease"? ***You are trying to impose your (inaccurate) intuition. An L and C, together not behave like an R and C. An RC circuit follows an exponential law. An L and C follow a sinusoidal variation in time; the energy, initially stored in the Capacitor does not get dissipated but passes into the Inductor and back again and so on. As the Voltage across the Capacitor approaches Zero, it changes faster and faster and (as it can hardly suddenly change direction or remain at zero) it carries on into the negative region.
I have to point out that an arm waving description of a process like this is really not adequate. There are some things for which a simple verbal description is just not enough - which is why Science can be very difficult. That's something people just need to accept. This link describes what happens and (with Maths, of course) derives an equation that describes the waveforms. Notice, the whole mathematical description takes up very little space because it is concise and cannot be misinterpreted - unlike so many other attempts at descriptions..
*** Explanation of why this idea is wrong: There is a constant amount of energy in the circuit, sloshing back and forth between the L and C.
Energy in a Capacitor is CV2/2
Energy in an Inductor is LI2/2
As Vc reduces, the energy drops faster and faster because of the squared term. This means that the Current IL has to be Increasing to a Maximum as VC passes zero.
With a CR circuit, the current drops as the VC drops; the Energy decays.
  • · Replies 27 ·
17K
  • · Replies 28 ·
