Chasing Cars Problem: Find GC Speed to Catch BC
  • Thread starter Thread starter Sparda
    Cars
Sparda
A blue car pulls away from a red stop-light just after it has turned green w/ a constant acceleration of .6 m/(s^2).
A green car arrives at the position of the stop-light 4.5s after the light had turned green.
What is the slowest constant speed which the green car can maintain and still catch up to the blue car?
Answer in units of m/s.
Formulas: Kinetmatics equations:
f=final, i=initial, x=position, v=velocity, a=acceleration, t=time
1. Vf = Vi + at
2. Xf = Xi + Vi(t) + .5a(t^2)
3. (Vf ^2) = (Vi ^2) + 2a(Xf - Xi)
may also need general formula : V=at
Vi of BC = 0 m/s
a of BC = .6 m/(s^2)
Xi of BC = 0
using formula 2, I have found out that Xf of BC @ 4.5 seconds = 6.075 meters.
Need to Find Vf for GC! (remember for green car Vf = Vi stated in the problem, constant speed)
Thanks for your help!
1. Vf = Vi + at
Vi of BC = 0 m/s
Xi of BC = 0
If you plot speed vs. time on a graph for both cars (distance being the area under the graph) you will easily solve this problem . In order for the green car to catch up, the area under its vt graph at some positive time t has to be equal to or greater than the area under the vt graph of the accelerating blue car.
The distance that the green car catches up on the blue car is the area between the green and blue graphs. Green will catch up only if this distance is greater than the initial deficit (ie the area under the blue graph when the green car reaches the origin, at t=4.5 sec).
AM
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
