Chemical Equilibrium: Understanding & Equation
The discussion focuses on the concept of chemical equilibrium, including its definition, the formation of the equilibrium equation, and the role of physical states of matter in equilibrium. Participants explore both theoretical and practical aspects of equilibrium in chemical reactions.
  • One participant suggests that the equilibrium constant remains approximately the same regardless of the amounts of reactants or products.
  • Another participant clarifies that the equilibrium constant is constant for a given temperature, not approximately the same.
  • A participant explains that chemical equilibrium occurs when the rates of the forward and reverse reactions are equal, providing an example of a reaction.
  • There is a discussion about the derivation of the equilibrium expression from rate laws, emphasizing the complexity of the mathematics involved.
  • Participants note that the phases of reactants and products affect the equilibrium constant, with solids not being included in the equilibrium expression.
  • One participant simplifies the concept of chemical equilibrium as a stable state of reactants and products, mentioning that changes in temperature or concentration can shift this equilibrium.
Participants express differing views on the nature of the equilibrium constant and its constancy. While some agree on the definition of chemical equilibrium, the understanding of how the equilibrium constant behaves under varying conditions remains contested.
There are unresolved assumptions regarding the specific conditions under which the equilibrium constant is considered constant, as well as the implications of physical states on equilibrium expressions.
Interception
Can someone help me understand the concept of chemcial equilbrium. I think I understand in a certain chemical reaction, know matter the amount of reactants or products, the equilibrium constant will remain approximatly the same. I don't fully understand how the equation to solve for the equilibrium is formed. Also, is there a physical equilibrium, as in the phase of matter of the reactants and products?
Chemistry news on Phys.org
For a given temperature equilibrium constant is not "approximately the same" - it is constant.
Hard to help with other things not knowing where your problem lies. General approach to solving equilibrium problems is to list all reactions, write all reaction quotients and write all mass balances and a charge balance - that yields a set of equations that have to be solved. What is left is just a math that usually gets nasty. You will spend most of your time learning tricks that help simplify finding a solution.
Chemical equilibrium is the state of a reaction in which the rate of the forward reaction is equal to the rate of the reverse reaction. For instance, A + B > C. The rate at which A and B are combining to form C is equal to the rate at which C is decomposing into A and B. As Borek said above, the equilibrium constant is exactly that - a constant for specific temperatures. It changes at different temperatures because the rates of reactions change at certain temperatures. The equilibrium expression can be derived by rate laws, for example, knowing that the forward and reverse rates are equal it can be written that kf[A] = kr[C], which implies that kf/kr = [C]/([A]) and K = [C]/([A]). This is called the law of mass action, and if you want to understand its derivation even further it involves some highly complex math. Just be satisfied (for now) that it was derived using countless empirical data a long time ago before Rate Laws even existed.
The phases of individual reactants and products are important to equilibrium because there are different equilibrium constants for different phases. Solids are NOT incorporated into your equilibrium expression because the concentration of a solid is simply 1. For instance, if you were to say a solid has a concentration in mol/L, well, we know that moles are proportional to volume. Thus, if you increase the amount of moles of that solid, it's volume will increase proportionally, and thus its concentration remains 1. For gases, the equilibrium expression will make use of pressures. For aqueous reactants/products, the equilibrium expression will make use of concentrations in molarity or often times molality. It just depends.
Hopefully this answer helped you. :)
Put simply, Chemical equillibrium is when a reaction has stopped reacting and is at a point of being stable, think of it as a balance of reactants and products. once the temperature, concentration etc changes, the point of equillibrium changes.
