bjoyful
- 61
- 0
I have been working on this assignment for several days, but I am not sure I am doing it 100% right. Any help will be appreciated!
1. Homework Statement :
1. For the NEW bottle of hydrogen peroxide, record and calculate the following:
(a) Volume of potassium permanganate used in each titration (mL):
(b) The volume of potassium permanganate required to titrate 10 mL of the new hydrogen peroxide (mL):
(c) Calculate the concentration of H2O2 from the volume of KMnO4 used and the stoichiometry of the reaction (MW of H2O2 is 34.01).
2. Repeat the calculations for the OLD bottle of H2O2:
(b) The volume of potassium permanganate required to titrate 10 mL of the old hydrogen peroxide (mL):
(c) Calculate the concentration of H2O2 from the volume of KMnO₄ used and the stoichiometry of the reaction (MW of H2O2 is 34.01).
3. Commercial hydrogen peroxide contains small amounts of organic compounds that are added to stabilize it. If these compounds react with permanganate, how would this affect your results?
2. Homework Equations :
I think I am suppose to be using the formula 5(C1xV1) H2O2 = 2(C2xV2) KMnO4. I know that the ratio is 2 to 5.
3. The Attempt at a Solution :
For the new bottle of H2O2: I started out with 50mL of potassium permanganate in my burette. I then mixed 10mL new hydrogen peroxide and 2mL sulfuric acid in the flask. When I titrate, the color turns purple at 31.95.
For the old bottle of H2O2: I started with 50mL of potassium permanganate in my burette. I then mixed 10mL old hydrogen peroxide and 2mL sulfuric acid in the flask. When I titrate, the color turns purple at 37.35.
I am uncertain for question "a" if the answer should be 50ml because I didn't really use 50mL. Once again, I am not sure if "b" is looking for 50.00-31.95=18.05 or something else. I am not sure if I am reading the question correctly. For "c", I am really confused! However, I have been trying to work through it! I started with the new bottle of H2O2 and used the formula 5(C1xV1) H2O2 = 2(C2xV2) KMnO4, I put 34.01 for C2 and 18.05 for V2 and multiplied both of them by 2, getting 104.12 as a total answer. I was putting 12ml for V1, but that is as far as I got.
I really need some help on this...I hope you can see that I have spent hours on this homework, and really need help - I am not looking for handouts!
Thanks!
Thanks!
