How to Derive the Chern-Simons Contribution to the Effective Action?
Kirjava
Hi PF,
I'm still very much a novice when it comes to QFT, but there's a particular calculation I'd like to understand and which (I suspect) may be just within reach. In short, the result is that after coupling a system of fermions to an external U(1) gauge field, one obtains a Chern-Simons contribution to the low-energy effective action of the gauge field by integrating out the fermions. Supposedly the coefficient of this (presumably lowest order) term can be computed from a single Feynman diagram to give the expression (here for d = 2+1)
C_2 = \int \mathrm{d}^3 k ~ \epsilon_{\mu \nu \rho} G \partial_{\mu} G^{-1} G \partial_{\nu} G^{-1} G \partial_{\rho} G^{-1}
with G the two-point greens function. The Feynman diagram in question is depicted on the review article page I refer to below.
Sticking to d=2+1 the effective action of this gauge field then looks like
S_{eff}[A] = \frac{C_2}{2 \pi} \epsilon^{\mu \nu \rho} A_{\mu} \partial_{\nu} A_{\rho}
I'd basically like to know how this calculation is done. To be precise, starting with the expression
e^{iS_{eff}[A]} = \int D[c] D[c^{\dagger}] e^{iS(c,c^{\dagger}) + iA^{\mu}j_{\mu}}
and by assuming that A is slowly varying, how would one go about deriving the above?
I know a bit about Feynman diagrams and the path-integral formalism, but apparently not enough to understand how this is done. For those who might be intersted, the context for my question is given on page 36 of this review: http://arxiv.org/pdf/1008.2026v1.pdf, but I haven't found the references cited there particularly helpful. Given the way this result is talked about there and elsewhere in the literature I'm presuming that the techniques required are fairly standard, and that somebody with more experience around here might therefore be in a position to help.
Cheers,
a student
I think the book by A. Zee, Quantum Field Theory in a Nutshell, Princeton, contains all you need.
In chapter IV.3 he describes how to calculate the effective action and in chapter VI.1 he shows how to calculate the term you are looking for.
Of all the references I find Dunne's approach on page 52 of http://arxiv.org/pdf/hep-th/9902115v1.pdf the most understandable. He shows exactly how the Chern-Simons term arises through an explicit computation and obtains its coefficient. Unfortunately these computations are carried out for Dirac propagator \frac{1}{(i{\not \partial} + m)} <br /> and it's not clear that the same reasoning can be easily extended to get the result for more general G posted above.
On the other hand Golterman on page 4 of http://arxiv.org/pdf/hep-lat/9209003v1.pdf seems to obtain the desired result in full generality with elegance and hardly any effort - although he doesn't explain in detail how the Chern-Simons term arises in the first place. Instead the idea seems to be
(1) Assume that a Chern-Simons term exists in the effective action, and calculate its coefficient by writing down a single Feynman diagram(?).
(2) Rewrite the contribution of this diagram by replacing everywhere the "photon vertex" with a partial derivative of the propagator (by invoking what looks like local charge conservation).
Unfortunately I don't understand either of these steps very well. For instance, I'm not sure what a "photon vertex" could mean given that our gauge field is fixed. I also lack the clarity to see that the Chern-Simons term coefficient should be given by the diagram he writes down. Maybe I was wrong about all this being in reach of my knowledge - perhaps I'll have to come back when I've got a sturdier grasp on the fundamentals (I suppose Zee would be a good place to start). But it's hard to let go!
So maybe someone will be interested in either pointing out the flaw in or carrying this meagre start on a derivation a little bit further:
We want to compute
S_{eff} = \mathrm{log} \, \mathrm{det} (G^{-1}+ {\not A}) = \mathrm{tr} \, \mathrm{log} (G^{-1}+ {\not A}) <br />
where G is a propagator which could carry the name of Dirac, or perhaps be something more appropriate to a lattice model (in this case "A-slash" would have to be suitably re-interpreted). Now, suspecting that it will lead to the CS form, expand the logarithm and extract the second order term:
S_{eff}^{(2)} = \frac{1}{2} \mathrm{tr} (G {\not A} G {\not A}) .
Now we (read: I) scratch our heads thinking about how the products of A in this term will turn into the desired product of A \partial A...
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
