Prove Chern-Simons Dispersion Relation | Carrol, Field, Jackiw
In summary, the conversation is about a formula involving omega, k, and p that has a corresponding dispersion relation. The formula is a linear operator on a 3-component vector and can be represented by a 3-by-3 matrix. The objective is to find the eigenvalues of this matrix, which will lead to the desired result. The conversation ends with expressions of gratitude and well wishes from the participants.
zwicky
Hi everybody!
Is there someone that can help me to prove that
[tex]
\omega^2E-k^2E=-ip_0k\times E+i\omega p\times E
[/tex]
imply that the dispersion relation is
[tex]
(k^\mu k_\mu)^2+(k^\mu k_\mu)(p^\nu p_\nu)=(k^\mu p_\mu)^2
[/tex]
Thanks in advance ;)
p.d. The reference for this formula is the paper of Carrol, Field, Jackiw, Limits on a Lorentz and parity violating modification of electrodynamics
The right hand side is a linear operator on the 3-component vector E, so it can be represented by
a 3-by-3 matrix, and what you really need to do is find the eigenvalues of this matrix. It's a matrix of the form
[tex]
\begin{pmatrix}
0 & v3 & -v2 \\
-v3 & 0 & v1 \\
v2 & -v1 & 0
\end{pmatrix}
[/tex]​
In general, the three eigenvalues of this matrix are i|v|, 0 and -i|v|. In this case [itex] v = -ip_0k + i\omega p [/tex]. That will get you to the result quoted.
Best
Dave
Muiti obrigado Dave!
Best from Brazil!
Zwicky
FAQ: Prove Chern-Simons Dispersion Relation | Carrol, Field, Jackiw
1. What is the Chern-Simons dispersion relation?
The Chern-Simons dispersion relation is a theoretical framework that describes the behavior of excitations in certain materials, particularly topological insulators. It relates the momentum and energy of these excitations, known as quasiparticles, and is important for understanding the properties of these materials.
2. Who discovered the Chern-Simons dispersion relation?
The Chern-Simons dispersion relation was first proposed by physicists Sean Carroll, Timothy Field, and Roman Jackiw in 1984. Their work was based on the earlier Chern-Simons theory developed by mathematicians Shiing-Shen Chern and James Simons.
3. What is the significance of the Chern-Simons dispersion relation?
The Chern-Simons dispersion relation is significant because it helps explain the behavior of topological insulators, which have unique properties and potential applications in fields such as quantum computing and spintronics. It also has implications for other areas of physics, such as particle physics and cosmology.
4. How is the Chern-Simons dispersion relation derived?
The Chern-Simons dispersion relation is derived using mathematical techniques from quantum field theory. It involves applying the equations of motion to the Lagrangian of a system with topological properties, resulting in a non-trivial dispersion relation for the quasiparticles.
5. What are some ongoing research developments related to the Chern-Simons dispersion relation?
Current research on the Chern-Simons dispersion relation includes efforts to experimentally verify its predictions in topological insulators and other systems. There is also ongoing work to extend the framework to more complex materials and to better understand its implications for other areas of physics. Additionally, there is ongoing debate and exploration around the role of the Chern-Simons term in the dispersion relation and its relation to other physical phenomena.
