Choosing the Optimal Dr Value for Sub-Cylinder Thickness in Solution
  • Thread starter transgalactic
In summary: The radius of a ring is r, so the length is rd\theta, and the width is dr. So the area of one 2D ring is rA.
transgalactic
1,395
in this solution:
http://i39.tinypic.com/2e4w7f4.gif
they chose thivkness to be dr
althogh r is the radius of a sub cilinder.
Read the paragraph that starts "To analyze the problem, we divide the silicon into concentric elements..." (emphasis added)
i don't understand this thing of taking a small ring
i can try and take a small 3d part
breaking it into 2d rings
and each ring breaks into small parts
so we start from defining this small part:
our radius of a ring is r
the width is dr
so the area of one 2d ring is
[tex]
\int_{a}^{b}\int_{0}^{2\pi}rd\theta dr=\pi(b^2-a^2)
[/tex]
our formula for calculating R is [tex] R=\frac{L}{\sigma A}=\frac{L}{\sigma \pi(b^2-a^2)}[/tex]
but they got other result
where is the mistake in my way?
Your mistake is that the area you are thinking about is different from the one in the article. You are thinking about a ring, or annulus, and the article is talking about the surface area of a concentric shell of silicon that runs the length of the coax conductor.
The formula you show is correct for the area of an annulus (a ring), but not for the the surface area of a long cylindrical shell, just like what they show in figure a. Is that clear?
but in the end it doesn't matter how we calculate the area
i should get the same result
It does matter, since you and the article are calculating different areas. You are calculating the area of a 2D shape that is a circle with a circular hole in it. The text is calculating the surface area of 2D shape wrapped around a long 3D cylinder. The two formulas are completely different.
"area of 2D shape wrapped around a long 3D cylinder"
i can't imagine that
can you explain that term??
OK, how about this. You know what a log (made of wood) is, right? That's a 3D object. Now wrap a sheet around the log. The sheet is a 2D object wrapped around a 3D object.
so they are making an integral (sum of sheets).
we calculate the resistivity of one sheet and make an integral for every sheet
every time the r is changing
why do i need dr??
R=\frac{L}{\sigma A}=\int_{a}^{b}\frac{L}{\sigma 2\pi r}
Staying with the log analogy. A log has tree-rings, each with a different radius. You need to find the resistance of all those rings together.
1. What is the purpose of choosing the optimal Dr value for sub-cylinder thickness in solution?
The optimal Dr value for sub-cylinder thickness in solution is chosen to ensure the most efficient and accurate results in experiments involving sub-cylinder measurements. This value helps to minimize errors and provide more precise data analysis.
2. How is the optimal Dr value determined for sub-cylinder thickness in solution?
The optimal Dr value is determined through extensive experimentation and data analysis. Factors such as the composition of the solution, the size of the sub-cylinder, and the desired accuracy of the results are taken into consideration to determine the most suitable Dr value.
3. Can the optimal Dr value change for different solutions and sub-cylinder sizes?
Yes, the optimal Dr value may vary depending on the composition of the solution and the size of the sub-cylinder. It is important to determine the optimal Dr value for each specific experiment to ensure accurate and reliable results.
4. What happens if the wrong Dr value is chosen for sub-cylinder thickness in solution?
If the wrong Dr value is chosen, it can result in inaccurate measurements and data analysis. This can lead to misleading results and compromise the validity of the experiment. It is crucial to carefully select the optimal Dr value to ensure the reliability of the data.
5. Are there any other factors to consider when choosing the optimal Dr value for sub-cylinder thickness in solution?
In addition to the composition of the solution and the size of the sub-cylinder, other factors such as the sensitivity of the measuring equipment and the temperature of the solution should also be taken into account when determining the optimal Dr value. These factors can affect the accuracy of the measurements and should be carefully considered during the selection process.
