Find Area of Circle Segments: Chord Length 4cm, Radius 3.3cm
  • Thread starter Thread starter MASH4077
    Area Circles
A chord of length 4cm divides a circle with a radius of 3.3cm into two segments, with one segment's area calculated as approximately 1.84 cm². The initial calculation for the second segment's area was incorrectly based on the formula for the area of a circle, leading to an erroneous result of 66.58 cm² instead of the expected 32.38 cm². The correct approach involves drawing radius lines to the chord's endpoints, forming an isosceles triangle, which allows for the determination of both the triangle's area and the angle between the radius lines. This information is essential for accurately calculating the area of the segment bounded by the chord. Understanding these geometric relationships is crucial for solving the problem correctly.
MASH4077
A chord of length 4cm divides a circle of radius 3.3cm into two segments. Find the area of each segment.
I've managed to workout the area of one of the segments (approx 1.84 cm^2). This is the correct solution given in my answer booklet.
The second segment area would therefore be 2*pi*(3.3)^2 - 1.84 = 66.58 cm^2.
But my answer booklet says its: 32.38 cm^2.
Can someone point me in the right direction on this one because I'm completely lost.
Thanks.
Oops, I've just realized.. wrong equation for the area of a circle. Don't bother with this question.
Why did you do 2*pi*r^2 for the area of the second segment?
Draw the radius lines to each end of the chord. This creates an isosceles triangle.
You should be able to determine both the area of the triangle and the angle between the radius lines.
Use that information to determine the area of the segment bounded by the chord.
