Circuits - Power and Resistivity
The discussion focuses on calculating the length of a Nichrome wire used in a heating coil with a power rating of 530 W at 110 V. The initial calculations yield a resistance of 22.83 ohms, leading to an estimated wire length of approximately 4.07 meters based on the resistivity of Nichrome at 20°C. However, the user suspects an error in their calculations, as they believe the answer is incorrect, and mentions discrepancies in resistivity values found on Wikipedia. Additionally, they express uncertainty about whether the teacher may have made a miscalculation. The conversation highlights the complexities of electrical resistance and the importance of accurate resistivity values in such calculations.
NemaxameN
A 530 W heating coil designed to operate from 110 V is made of Nichrome wire 0.500 mm in diameter.
(a) Assuming that the resistivity of the Nichrome remains constant at its 20.0°C value, find the length of wire used.
(b) If the diameter of the wire were doubled, how long would the wire be if it had the same resistance?
My chart says rhoNichrome=1.1E-6
P=VI
V=IR
rho=R(A/l)
A=pi*r^2
0.5/2=0.25 (radius)
pi*(0.25)^2=0.196mm^2 = A
V=IR => I=V/R
P=V(V/R) => 530=110^2/R
R=22.83 ohms
1.1E-6=22.83(0.196E-6/l)
l=~4.07m
But this answer is wrong. If someone could help me find my mistake in part A, I can work part B. Thanks!
Looks okay to me. Wikipedia has rhoNichrome= 1.5 E-6 ohm-meter
That gave me 2.98m and 11.95m. Both were still wrong. Hmmm. It's possible my teacher made a miscalculation, she does that fairly frequently. Thank you though!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
