Circular motion graph of a ball
The discussion revolves around solving three physics problems related to circular motion. The first problem involves a ball on a string, where the tension is known, and the goal is to determine where the ball will land after the string is cut. The second problem focuses on a conical pendulum, requiring the calculation of angular velocity after finding the tension. The third problem deals with a sphere revolving in a horizontal circle, where participants struggle with calculating the tension in the wires supporting the sphere. Key insights emphasize the importance of incorporating gravitational forces and using proper kinematic equations to solve these circular motion scenarios effectively.
bk12321
Sorry for posting 3 problems, but I have 25 due and I am just not grasping the material...
[[[[[[ #1 ]]]]]]
A 100 g ball on a 60 cm long string is swung in a vertical circle about a point 200 cm above the floor. The tension in the string when the ball is at the very bottom of the circle is 4.0 N. A very sharp knife is suddenly inserted, as shown in the picture, to cut the string directly below the point of support. Where does the ball hit the floor? (Measure from the point where the string was cut and consider right to be the positive direction.)
http://img151.imageshack.us/img151/6631/p751fl2.gif
F=(mv^2)/r
and the constant accel kinematic equations
f=mv^2/r
=sqrt((netforce*r)/m)
v=1.54919
then i use y(final)=y(initial)+1/2at^2
0=(.2-.06) + 1/2(-9.81)t^2
t^2=-.14/-4.9
t=.169
plugging in for x
xfinal=xi+vt
xfinal=0+(1.549m/s)(0.169s)
not getting the right answer tho...
i suck at physics
[[[[[[ #2 ]]]]]]
A conical pendulum is formed by attaching a 400 g ball to a 1.0 m long string, then allowing the mass to move in a horizontal circle of radius 14 cm. The picture shows that the string traces out the surface of a cone, hence the name.
http://img151.imageshack.us/img151/8415/p739hd6.gif
f=mv^2/r
I found the tension force F = 3.924N, which was part a
anyways its right, but I need the second part which says:(b) What is the ball's angular velocity, in rpm?
I don't know how do do that, I used w=sqrt(f/mr) and then multiplied by 60sec/1min and then divided by 1revolution/2pi radians, but the answer is wrong.
[[[[[[ #3 ]]]]]]
Two wires are tied to the 320g sphere pictured. The sphere revolves in a horizontal circle at a constant speed of 6 m/s. What is the tension in each of the wires?
http://i9.photobucket.com/albums/a71/bk12321/p7-61.gif
f=mv^2/r
t=netforce, if gravity doesn't come into play
since they are both acting on the ball, 2t=the net force on the x axis
You just have to find the tension force in each wire. I solved it but I'm getting the wrong answer :(. This one seems to be the easy one but I just can't get the right answer so I am dumb.
net force=mv^2/r
=(.32kg)(6m/s)^2/.866m
=13.3N
from there I took cos(theta) and multiplied it and did some other stuff, and then divided the total tension force by 2 since the tensions should be equal, but the answer is wrong... so some help with the part after finding the net force would be awesome
thanks a ton
I wish I could get physics like I do calc II...
no help?
For the first problem you need to consider the tension, and the gravity...
net force = mv^2/r
what is the net force (using gravity and tension)...
also for the kinematics part... 200cm = 2m. 60cm = 0.6m.
for the second problem... w = v/r, where r is the radius of the circular path... get v using centripetal motion... then you can get w...
For the third,
I think you need to consider gravity... suppose T1 is the force in the top string. T2 is the bottom.
sum of the vertical forces = 0
plug in the appropriate forces above
sum of horizontal forces = mv^2/r
2 equations... 2 unknowns. you can get both the tensions.
For your first question,
Since tension is given, and you know the gravitational force at the bottom and you know that these difference is equal to the centripetal force. The solution to this equation gives you the velocity in the x direction.
With the velocity in the x direction and an accelaration due to gravity, can you find the position of the ball??
The scenario after the string is cut is similar to throwing a stone on a cliff in x direction.
