Circular Motion of a ball Problem
A 60 g ball is swung in a vertical circle on a 50 cm string, and the problem involves determining where it lands if released at the top of the loop. The critical velocity for the ball to maintain tension in the string is calculated using the formula Vc = √(r*g), leading to a corrected value of 2.2 m/s after addressing initial calculation errors. The time taken for the ball to fall 2 meters is calculated to be approximately 0.64 seconds. The horizontal distance traveled by the ball is then determined to be about 1.4 meters. The discussion highlights the importance of accurate calculations in physics problems.
cse63146
A 60 g ball is tied to the end of a 50-cm-long string and swung in a vertical circle. The center of the circle, as shown in Figure, is 150 cm above the floor. The ball is swung at the minimum speed necessary to make it over the top without the string going slack.
If the string is released at the instant the ball is at the top of the loop, where does the ball hit the ground?
http://session.masteringphysics.com/problemAsset/1000600/5/knight_Figure_07_62.jpg
Critical velocity = V{c} = \sqrt{r*g}
\Deltad=V{i}*t + (1/2)(a)(t^2)
I attempted this problem as a projectile motion problem, and divided the calculations into two parts: Horizontal and Verticle
Verticle Part
So I used this equation: \Deltad=V{i}*t + (1/2)(a)(t^2) and I know the verticle initial is 0 so I can eliminate V{i}*t of the equation and get: \Deltad=(1/2)(a)(t^2)
2 = (1/2)*(9.8)*(t^2)
2 = 4.9*(t^2)
t^2 = 2 / 49
t = 0.64 seconds
Horizontal Part
The horizontal parts only has 3 variables: V, d, and t (which I know from the verticle part). and V = V{c} = \sqrt{r*g} = 0.59 m/s.
and d = v*t = 0.59*0.64 = 0.3776 m
This doesn't look right. I was wondering if someone can point me in the right direction. Any help is greatly appreciated. Thanks.
Looks ok except for a math error in your critical speed calc.
yea I see what you mean. I accidently used the mass instead of the radius.
so it would be v_{c}=\sqrt{r*g} = \sqrt{0.5*9.8} = 6.9
therefore:
d = v*t = (6.9) * (0.64) = 4.4 m/s?
Does this seem right?
Edit: Still not the right answer. Help?
What are you asked to find? (I don't see a question in the problem statement.)
oops.Sorry about that.
therefore:
you've made anoteher math error,
\sqrt{r*g} = \sqrt{0.5*9.8}= \sqrt4.9 = 2.2m/s And then calculate the distance d which wil be in meters.
yep
d = v*t = 2.2*0.64 = 1.4 m
Thanks a lot!
still can't figure out why I put down 6.9 instead of 4.9...
