How do you calculate the average acceleration of a particle in circular motion?
To calculate the average acceleration of a particle in circular motion, it's crucial to understand that the average acceleration refers to the average vector acceleration, not just the magnitude. The particle moves along a semi-circular path with a radius of 5m and a constant speed of 11 m/s. The correct approach involves determining the radial acceleration at various points and integrating over the path, considering the symmetry of the situation. The average acceleration can also be derived using the formula for average vector acceleration, which is the change in velocity divided by the change in time. Properly applying these principles will yield the correct average acceleration for the semi-circular motion.
brandon26
A particle moves in a semi circular path AB of radius 5m with constant speed of 11s^-1.
What is its average acceleration:
I worked it out but it was wrong, what i did was:
average acceleration = average velocity / time and got 4.8ms^-2.
Someone help please?
This problem is a little more complex the way I read it. I assume is asking for the average vector acceleration not the average magnitude of the acceleration vector.
So what you have to do is work out what the acceleration is at any point on the semi-circular path (you should know an expression for the radial acceleration of a body moving in a circle.) Then you need to integrate over the path to get the average acceleration. You can do that integral by components, and you can see by symmetry of hte situation that one of the integrals is zero.
So when you figure out the geometry, etc, you'll find that you basically need to work out what one component of the acceleration is along the semi-circular path, and then average it using the integral.
Isn't it simply a_c = \frac{v^2}{r}?
What's a semicircular path?
I interpreted the question to mean that you only consider the average over half a circle and that is why the semicircular path is mentioned and the "average" acceleration is asked for.
Another way to solve it is to simply use the definition of average (vector) acceleration:
\vec{a}_{ave} = \frac{\Delta \vec{v}}{\Delta t}
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
