Circular Motion Problem: An Adventure inside Spinning Cylinders
A 60.0 kg person is experiencing circular motion inside a rotating cylinder with a radius of 10.0 m and a period of 2.00 s. To prevent sliding, the frictional force must counteract the gravitational force acting on the person. The net force can be calculated using the equation Fnet = (4m∏^2R)/T^2. The discussion highlights the need to determine the minimum coefficient of static friction required for the person to remain stationary against the wall. Understanding the balance of forces is crucial for solving this problem effectively.
victoration1
A 60.0 kg person is stuck against the inner wall of a rotating cylinder.
The radius of the cylinder is 10.0 m and the period is 2.00s. What is the
minimum coefficient of static friction required to stop him from sliding?
Fnet = (4m∏^2R)/T^2
Tried to understand the problem; could not even. What is the condition for not sliding?
Fnet = (4m∏^2R)/T^2
"What is the condition for not sliding?"
The frictional force needs to be great enough to cancel the gravitational force.​
