Circular Motion with time-dependent radial acceleration
The problem involves a particle moving in circular motion with a time-dependent radial acceleration described by the equation a_r = At^4. The particle's initial position is given, and the tasks include finding the distance traveled as a function of time, and expressing the particle's acceleration in both polar and Cartesian coordinates.
  • The original poster attempts to relate radial acceleration to velocity and distance traveled, but questions the impact of changing radial acceleration on their solution. They also express confusion about converting acceleration from polar to Cartesian coordinates.
  • Some participants clarify that the motion is not uniform due to the changing radial acceleration and affirm that the equation a = v^2/r applies to circular motion.
  • Further inquiries arise regarding the existence of tangential acceleration and hints are sought for its determination.
The discussion is active, with participants exploring the implications of non-uniform motion and the relationship between radial and tangential acceleration. Guidance has been provided regarding the differentiation of velocity to find acceleration, but no consensus has been reached on the specific methods to apply.
The problem context includes the assumption of circular motion and the need to address the changing nature of radial acceleration, which may affect the calculations. There is also a lack of explicit definitions for the unit vectors in polar coordinates, which is under discussion.
TwoSeventyOne
A particle is traveling on a circle with a radius R. The particle's radial acceleration is given as:
[itex]a_r=At^4[/itex]
At time [itex]t=0[/itex] the particle is at [itex](R,0)[/itex].
A. Find the distance that the particle has traveled as a function of time [itex]S(t)[/itex].
B. Display the particle's acceleration in polar coordinates.
C. Display the particle's acceleration in Cartesian coordinates.
##a_r=\frac {v^2} {R}##
##x=rcos\theta, y=rsin\theta##
I assumed at first that since the particle is moving in a uniform circular motion, I can use
[itex]a_r=\frac {v^2} {R}[/itex]
[itex]At^4=\frac {v^2} {R}[/itex]
[itex]v=\sqrt{RAt^4}[/itex]
Then I treated [itex]v[/itex] as [itex]\frac {ds} {dt}[/itex] and got
[itex]S(t)=\sqrt{RA}*\int_0^t t'^2 \, dt' = \frac{\sqrt{RA}t^3} {3}[/itex]
But then I realized that the radial acceleration changes according to time. Wouldn't that affect the solution? Also, I'm confused as to converting the acceleration from polar to Cartesian. I'm not sure if the same rules apply to acceleration and exactly what are my ##\hat r## and ##\hat \theta##.
There is nothing stating that the motion is uniform. In fact, the changing radial acceleration tells you that it is not. However, ##a = v^2/r## holds for any circular motion - otherwise the particle would not be moving in a circle.
I see. Does that mean that there is necessarily tangential acceleration as well? If so, any hint on finding it?
Yes, there must be a tangential acceleration. You have already found the velocity, so finding the acceleration is a simple matter of differentiating.
  • · Replies 29 ·
  • · Replies 16 ·
11K
