Circular motioni, work question.
  • Thread starter Thread starter Miike012
    Circular Work
In the scenario of a ball being swung in a circle at constant velocity, the forces acting include tension in the string and gravitational force, but only the tension does work on the ball. The discussion emphasizes the need for clarity in defining the problem, such as specifying the environment (e.g., gravitational field or space) and the mechanism of swinging. Participants highlight that understanding the context is crucial for accurately determining which forces perform work. The conversation underscores the importance of providing initial thoughts and a clear problem statement to facilitate meaningful assistance. Overall, the focus remains on the physics of circular motion and the role of forces in doing work.
Miike012
Senario: A string is tied to a ball and swung in a circle at constant velocity.
My question was... which forces are doing work?
with 500+ posts, you should know that you need to give us your thoughts before we can be of much help.
You should also define the problem better... are you talking about in a gravitational field like on the Earth? Or in space? What is "swinging" the ball?
this was a problem I just made up, so ill say a person is swinging a ball.
