What Calculations Determine Roller Coaster Dynamics on a Vertical Track?
  • Thread starter Thread starter dr2112
    Circular Track
The discussion focuses on calculating the dynamics of a roller coaster on a vertical circular track. Key calculations include determining the minimum speed required for the coaster to remain on the track at the top, which is derived from the equation v = square root of (rg). The speed at the bottom of the loop is linked to energy conservation principles, with the equation involving kinetic and potential energy. Additionally, the normal force experienced by passengers at both the bottom and top of the loop is analyzed using Newton's laws. Overall, the thread emphasizes applying physics equations to solve for speed and forces in roller coaster dynamics.
dr2112
roller coaster traverses a vertical circular track.
a)what speed must car have to make it over the top w/o leaving the track? assume it is not attached to track.
b)what will speed be at bottom?
c)what will normal force on passenger be at the bottom of loop if radius is 14.5m?
d)at the top?
a) EF=ma
n-mg=ma2
n=0 at top
b)Etop=1/2mv2(top)+mgh
a) v=square root of (rg)
b)1/2mrg+mg(2*3.14) =2.5mgr
c)?
d)?
Hi dr2112,
d)at the top?
a) EF=ma
n-mg=ma2
n=0 at top
The first term (1/2 mrg) looks right for the kinetic energy at the high point. What do the other two terms represent, and how did you get those numeric values?
c)?
Do the same thing for part c that you did in part a--use Newton's law for the forces.
d)?
You've already answered this in the working for part a.
