Circulation of a stream function
marklar13
The stream function of a 2D incompressible flow is given by:
\Psi=(\Gamma/2pi)*ln(r)
Show that the circulation about a closed path about the origin is \Gamma and is independent of r.
\Gamma=-\ointV dot ds
So far I know that the radial velocity component Ur=(1/r)*d(Psi)/d(theta)=0 because Psi does not depend on theta.
This means that the angular velocity component is the only velocity component: Utheta=-d(Psi)/d(r)=-L/2pi(r)
After this point I am not exactly sure what to do.
Cant really understand the latex stuff... working on it
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
