Clarification on thermodynamics concepts of state function, exact differential
The discussion explores the relationships between state functions, exact differentials, and thermodynamic concepts such as conservative forces and reversibility. It highlights that while heat is typically considered an inexact differential, it can be expressed as an exact differential under certain conditions, specifically during reversible processes. The conversation emphasizes that thermodynamics is fundamentally time-dependent, contrasting it with thermostatics, and notes that the dynamic theory of thermodynamics remains incompletely formulated. Additionally, it addresses the importance of specifying conditions, such as reversibility, when defining state variables and integrating factors. Overall, the complexities of thermodynamic processes reveal deeper insights into the nature of energy transfer and system behavior.
aurorasky
I would like someone to explain to me the correlations between these thermodynamics concepts:
1 State function/conservative force/reversibility
2 State function/exact differential
Some functions in the phase space of a system are state function some are not. Is this simply an empirical fact or is there something deeper about it?
AFAIK, heat, for instance, is an inexact differential, but it is also given by the mass times the specific heat times the variation in temperature so it is also expressible as an exact differential. How can it be?
Is the concept of state function only meaningful in a state of equilibrium?
What is the role of time in thermodynamics? Why we always write equation without any reference to time? Is it possible to write an equation of evolution of a thermodynamics system just like the laws of motion in classical mechanics?
Science news on Phys.org
This is indeed a deep question. Part of the answer was given by Caratheodry
http://www.jstor.org/stable/2100026
"state space" in thermodynamics is a contact space, not a symplectic space. "conservative" mechanical theories occur in symplectic space (exact differentials, etc), while dissipative systems occur in a contact space. It's possible to embed the contact space into a symplectic structure, but that has a restricted region of validity (AFAIK).
I suspect you have been shown equations of thermostatics- thermodynamics is a fully time-dependent theory, and thermokinetics is a linearized version of thermodynamics. The fully dynamic theory has not been completely formulated in any useful sense- there are still many open questions.
To heat an object, you not only change its temperature, but also its volume and pressure. The specific heat will generally depend on both volume and pressure (and whatever else). So the amount of energy imparted by heating is path dependent.
While it is not true that heat is both and exact and inexact differential, the above argument is not complete in the sense that we can make an exact differential dS, out of an inexact differential dQ, by dS=dQrev/T.
If a differential satisfies some "Maxwell relation", it is an exact differential. A factor such as 1/T which converts inexact dQrev to exact dS is called an integrating factor. http://pruffle.mit.edu/3.016-2005/Lecture_20_web/node2.html
In defining dS=dQrev/t, we have to specify that the heating occurs during a reversible process. A reversible process is a quasistatic process in which the work done is frictionless. If the process is not quasistatic, then the state variables are not defined during the process, and we don't know how to do the path integral. If work is done against friction, running a force backwards generates as much heat as running it forwards, so dQ/T cannot be zero even though the system is back in its initial state (in a sense, if there is irreversible work, we haven't properly included the heat into our equations for every stage of the process).
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
