Classical Mech doubt 4m Goldstein
In summary, there is no dependence on time in the definition of virtual displacement, and it only depends on the displacement of coordinates. This ensures that the virtual displacement is perpendicular to the force of constraint, even if the constraint is changing with time.
pardesi
339
Goldstein said:
Note that there is no dependence of time, [tex]\delta t[/tex] is involved here( in the definition of virtual displacement that is [tex]\delta \vec{r_{i}}=\sum_{j} \frac{d \vec{r_{j}} \delta q_{j}}{d q_{j}}[/tex] ) ,since a virtual displacement by def depends only on the displacement of coordinates.(Only then is the virtual displacement perpendicular to the force of constraint if the constarint itself is changing with time.)
Can someone Prove the thing in bold letters?
No, it is not possible to prove this statement. The statement is a definition of a virtual displacement, and as such cannot be proven.
The statement in bold is a fundamental concept in classical mechanics, known as the principle of virtual work. It states that for a system in equilibrium, the virtual work done by the applied forces and the virtual work done by the constraint forces must be equal. In other words, the sum of the dot product of the applied forces and virtual displacements must be equal to the sum of the dot product of the constraint forces and virtual displacements.
To prove this, we can start with the definition of virtual displacement, which is a hypothetical displacement that satisfies the constraints of the system. This means that the virtual displacement is perpendicular to the constraint forces, as any component of the virtual displacement in the direction of the constraint forces would violate the constraints.
Next, we can consider the definition of virtual work, which is the dot product of the applied force and the virtual displacement. Since the virtual displacement is perpendicular to the constraint forces, the dot product of the constraint forces and virtual displacement will be zero. Therefore, the virtual work done by the constraint forces is also zero.
Now, if we apply the principle of virtual work, we can see that the sum of the virtual work done by the applied forces and the sum of the virtual work done by the constraint forces must be equal to zero. This means that the virtual work done by the applied forces must be equal and opposite to the virtual work done by the constraint forces.
In conclusion, the statement in bold can be proven by applying the principle of virtual work and considering the definitions of virtual displacement and virtual work. This principle is a fundamental concept in classical mechanics and is crucial in understanding the behavior of systems in equilibrium.
1. What is Classical Mechanics?
Classical Mechanics is a branch of physics that deals with the motion and behavior of macroscopic objects, such as particles, bodies, and systems, under the influence of forces. It is based on the laws of classical physics, such as Newton's laws of motion, and is used to describe the behavior of objects in everyday life.
2. Who is Goldstein and what is his contribution to Classical Mechanics?
Herbert Goldstein was an American physicist and mathematician who made significant contributions to Classical Mechanics with his textbook "Classical Mechanics". He is known for his work on the equations of motion, Hamiltonian mechanics, and rigid body dynamics, among others.
3. What are the main concepts covered in Goldstein's book "Classical Mechanics"?
Goldstein's book covers a wide range of topics in Classical Mechanics, including kinematics, dynamics, Lagrangian and Hamiltonian formalism, central force motion, and rigid body dynamics. It also includes discussions on special relativity, variational principles, and chaos theory.
4. How is Classical Mechanics different from Quantum Mechanics?
Classical Mechanics and Quantum Mechanics are two different theories of physics that describe the behavior of objects at different scales. Classical Mechanics is used to describe the motion of macroscopic objects, while Quantum Mechanics is used to describe the behavior of subatomic particles. Classical Mechanics is based on deterministic laws, while Quantum Mechanics is based on probabilistic laws.
5. How is Classical Mechanics relevant in modern science and technology?
Classical Mechanics is still highly relevant in modern science and technology. It is the foundation of many engineering disciplines, such as aerospace, mechanical, and civil engineering. It is also used in fields such as astrophysics, geophysics, and biomechanics. Many modern technologies, such as cars, airplanes, and satellites, rely on the principles of Classical Mechanics.
  • Classical Physics
  • Mechanics
  • Classical Physics
