Classical mechanics confusions
Two identical objects interchange their velocities during a head-on collision due to the conservation of momentum, which is a vector quantity that considers both magnitude and direction. Momentum is not conserved if the objects merely reverse direction without changing their velocities, as this would alter the total momentum's direction. For objects with changing mass, such as a rocket losing fuel, the standard kinetic energy formula can still be applied, but care must be taken as the mass at any given time affects the kinetic energy calculation. The energy associated with the mass loss, such as the kinetic energy of the exhaust, must also be considered. Understanding these principles clarifies the complexities of classical mechanics in dynamic systems.
Faiq
Q1. What's the reason behind two identical objects interchanging their velocities upon head-on collision?
Why can't just each individual particles just reverse its direction and keep traveling at its original speed? Kinetic energies and momentum would still be conserved.
Q2. Why can't we use the formula of Kinetic energy where kinetic energy is half mass times velocity squared to find kinetic energies of objects whose mass is changing? Is there a way to modify the formula to get the desired output?
Are you sure about that?
How is the mass changing?
Q1: No, momentum is not conserved in your scenario. Momentum is a vector, it has magnitude and direction, and though in your scenario the magnitude of the momentum of each particle remains the same, the direction reverses for each particle, so the direction of the total momentum also reverse, so momentum is not conserved.
Q2: Not sure here, I think you can use the formula for kinetic energy but you can't use the work-energy theorem.
Likes cnh1995
I don't understand the distinction you are making between "interchanging their velocities" and "each individual ... just reverse direction...". If particle A is assigned the velocity of particle B after the collision, does particle A "just reverse direction" ?
What is your definition of "object"? The state of an object in classical mechanics includes a description of its mass. If the "object" represents a stick and you break it in half, which of the halves is the original "object"? It would help if you gave an specific example of a problem in classical mechanics where an "object" has a changing mass.
^ I think he means something like an accelerating rocket that is losing mass by combusting its fuel...
thank you for question 1
An object which is constantly gaining or losing mass, like spaceship losing mass by combusting its fuel
So you are asking why we cannot use ##E=\frac{1}{2}mv^2## to determine the current kinetic energy of a rocket ship that is losing mass as it fires its thrusters?
We can use ##E=\frac{1}{2}mv^2## to determine the kinetic energy of such a rocket. That formula will give a perfectly correct answer.
But if you add the starting kinetic energy of the rocket to the chemical energy in the fuel being burned you get a result that is (almost always) larger than the resulting kinetic energy of the rocket. There is some missing energy. Can you imagine where that "missing" energy might have gone?
Energy losses to such as friction?
Like if I have a problem like
A rocket has a mass of 16000kg. It loses mass at a rate of 15kg/s. It maintains a steady velocity of 200m/s. What is the Kinetic energy of the rocket?
What will be the value of m here?
That is not it. The rocket can be in space and the only force can be that of its own thrust. What about the kinetic energy of the exhaust stream?
What will be the value of m when? The mass of the rocket is changing over time. The kinetic energy of the rocket at a particular time depends on its mass at that time.
Yes that's what I was talking about. So is there a specific kind of energy for objects whose mass changes over time. Like kinetic energy is related with changes in motion, is there a type of energy related to changes in mass?
Kinetic energy is not specifically related to changes in motion. It is defined by ##KE=\frac{1}{2}mv^2##. The velocity there need not change. Nor must the mass be a constant.
Oh okay thanks
