Interference at Odd vs Even Harmonics: Is the Square Wave Really Square?
The Fourier transform of a square wave typically shows peaks at odd harmonics, but interference at even harmonics can occur under certain conditions. This can happen if the square wave deviates from an ideal shape, influenced by factors such as duty cycle and pulse width. Real-world signals often exhibit variations in rise and fall times, which can alter the harmonic content. Consequently, a square wave that is not perfectly symmetrical may produce unexpected even harmonics. Understanding these nuances is crucial for accurate signal analysis and device performance.
cyclone24
If I look at the Fourier transform of the square wave signal, the peaks are at the odd multiples. In the device that I am working on, I would expect the interference at the odd harmonics of the center frequency.
But I see the interference at even harmonics. When is this possible?
(Only if the square wave is not really square?)
Nothing is ideal in the real world.
The harmonic structure of a pulse signal depends on the duty-cycle. A real 50% square wave has the odd-harmonic structure you mention. Varying the pulse-width will produce different harmonics.
It turns out that the difference in rise and fall times lead to different harmonics (odd/even)...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
