Clocks Within Each Ship in Bell Spaceship Paradox
141 replies · 13K views
Stalin Beltran
- 9
- 0
harrylin said:4. The string will break at a certain moment, and as interpreted in S, this is due to length contraction because the distance between the rockets remains constant in this frame. Length contraction refers in this context to a change of the stress-free length of an object as observed from a single frame.
Point 4 is part of the initial conditions, or is it part of the conclusions achieved by analyzing the paradox?
harrylin
- 3,874
- 93
I don't know if anyone would have a problem with saying that the string breaks "because it is stretched". The discussion on p.3 is about the use in SR of accelerating frames instead of inertial frames.Mentz114 said:I don't know what you mean. In what sense is the string breaking because it is stretched not correct ?
harrylin
- 3,874
- 93
Apart of the definition, point 4 is my sketch of Bell's analysis. And of course, my main remark concerned point 3.Stalin Beltran said:Point 4 is part of the initial conditions, or is it part of the conclusions achieved by analyzing the paradox?
Stalin Beltran
- 9
- 0
harrylin said:Apart of the definition, point 4 is my sketch of Bell's analysis. And of course, my main remark concerned point 3.
That is important. I have been analyzing this paradox by taking little ##\Delta t##'s, and if the conditions are 1 to 3, the output will be no string broken (supposing I am right). I know we are not dealing that here, but I just wanted to be sure about the initial conditions.
harrylin
- 3,874
- 93
Yes the initial conditions are as described in Wikipedia.Stalin Beltran said:That is important. I have been analyzing this paradox by taking little ##\Delta t##'s, and if the conditions are 1 to 3, the output will be no string broken (supposing I am right). I know we are not dealing that here, but I just wanted to be sure about the initial conditions.
PS. if you find that the string doesn't break, then it may be a good idea to present your calculation here for debugging. Comparing the situations at t0=0 and t1 >>0 suffices for the analysis.
If you are getting that answer, then you are making a mistake somewhere. The Lorentz transformations show that:
- If the accelerations are equal in the initial rest frame, then the accelerations are unequal in other rest frames.
- In particular, in the comoving rest frame of one of the rockets, the acceleration of the front rocket is greater.
- So in the comoving rest frame of one of the rockets, the distance between the rockets is increasing.
- Therefore, the string should break.
Mentz114
- 5,429
- 292
OK. My point is that frames are irrelevant in the sense that we only need to find a frame independent analysis. The problem can be expressed in a frame independent way if we can find a Lorentz scalar that tells us if the ships are getting further apart. There is a tensor, ##\theta_{ab}=\partial_a u_b## which has a contraction ##\theta={\theta^a}_a## which tells us if the rockets move apart or get closer. For the case in question it is ##\gamma^3 a^2t##. The ships are moving apart.harrylin said:I don't know if anyone would have a problem with saying that the string breaks "because it is stretched". The discussion on p.3 is about the use in SR of accelerating frames instead of inertial frames.
The fact that people are using comoving frames to decide questions of physics and not getting clear answers makes me think those methods are very subtle and difficult to use. So, complicated and not needed for understanding.
Usually arguments that use the terms 'length contraction' and 'time dilation' are flawed. The only thing one can trust are Lorentz transformations and scalars. Of course relativity of simultaneity is a fact of life so the phrase 'at the same time' has to mathematically defined to be useful. In the rocket ships case there is no ambiguity because the simultaneity of the take-offs is attributed in one frame.
1977ub
- 530
- 22
Do you have an opinion regarding why there was so much confusion regarding Bell's Paradox, even among experts?
Mentz114
- 5,429
- 292
I'm as confused as anyone about this. But there is no observer who sits on the rope thinking 'why is the rope getting tighter when the ends are fixed ?' This is a mathematical fact as solid as you like. If the observer can't exist then the weird event can't exist and there is no need to 'explain' it. Trying to explain the impossible leads to confusion.1977ub said:Do you have an opinion regarding why there was so much confusion regarding Bell's Paradox, even among experts?
- 13,337
- 4,227
I only know that laymen often misunderstand length contraction as comparison between two time points (before and after acceleration), while in fact it compares two different frames. So they fail to see that keeping constant distance in the initial rest frame, implies stretching in the current rest frame.1977ub said:Do you have an opinion regarding why there was so much confusion regarding Bell's Paradox, even among experts?
To me the most intuitive explanation is replacing the string with a chain. The rigid chain links will get shorter in the initial frame, so they cannot span the same distance anymore.
In the case of a more solid string, the links are individual atoms which contract, or their EM fields which connect them to each other.
Mentz114
- 5,429
- 292
A.T. said:I only know that laymen often misunderstand length contraction as comparison between two time points (before and after acceleration), while in fact it compares two different frames. So they fail to see that keeping constant distance in the initial rest frame, implies stretching in the current rest frame.
I don't think that is possible. Any apparent contraction in length is offset by a change in the internal potentials caused by time dilation. The atoms would remain in unstretched equilibrium.
Can you show equations ?
- 13,337
- 4,227
If the distances between the atoms do not change, but forces between them increase, then their potentials must be have been contracted. How else would you explain the increasing stresses, based solely on the initial rest frame?Mentz114 said:I don't think that is possible. Any apparent contraction in length is offset by a change in the internal potentials caused by time dilation. The atoms would remain in unstretched equilibrium.
Mentz114
- 5,429
- 292
A.T. said:If the distances between the atoms do not change, but forces between them increase, then their potentials must be have been contracted. How else would you explain the increasing stresses, based solely on the initial rest frame?
Nothing I've written disproves what you suggest so that remains open and I'm not going to attempt to pursuade you in someone else's topic.
My position is that there is nothing to explain so it's irrelevant anyway. No disrespect intended.
Mentz114 said:OK. My point is that frames are irrelevant in the sense that we need only find a frame independent analysis. The problem can be expressed in a frame independent way if can find a Lorentz scalar that tells us if the ships are getting further apart. There is a tensor, ##\theta_{ab}=\partial_a u_b## which has a contraction ##\theta={\theta^a}_a## which tells us if the rockets move apart or get closer. For the case in question it is ##\gamma^3 \partial_t\beta=\gamma^3\ a##. The ships are moving apart.
I'm sorry, did you already define [itex]\theta[/itex]? The way you've defined it seems to treat [itex]u_b[/itex] as a vector field, but how is that defined?
I tried to come up with a covariant formulation of the problem, and it seemed sort of complicated. Here are my thoughts on this:
Suppose you just want to characterize how stretched a string is, in a covariant way. Here's my approach: We label a point along the string connecting the rockets with a number [itex]\lambda[/itex], which is the distance along the string from one end to that point. Then we could define [itex]\mathcal{P}(\lambda, \tau)[/itex] to be the event that the point labeled [itex]\lambda[/itex] passes through at proper time [itex]\tau[/itex].
In terms of [itex]\mathcal{P}(\lambda, \tau)[/itex] we can define two partial derivatives:
[itex]D^\mu = \frac{\partial}{\partial \lambda} \mathcal{P}[/itex]
[itex]U^\mu = \frac{\partial}{\partial \tau} \mathcal{P}[/itex]
[itex]U^\mu[/itex] is just the 4-velocity of the point on the string labeled [itex]\lambda[/itex]
So if we start at [itex]\lambda, \tau[/itex] and consider a nearby piece of the string at [itex]\lambda + \delta \lambda, \tau + \delta \tau[/itex], the separation will be, to first order:
[itex]S^\mu = D^\mu \delta \lambda + U^\mu \delta \tau[/itex]
Now, here's the tricky part, it seems to me. If we want to know the spatial separation between two nearby pieces of string, that means that we have to choose [itex]\delta \tau[/itex] so that [itex]S^\mu[/itex] is purely spatial, in the local comoving rest frame of the string. That means that
[itex]U^\mu S_\mu = 0[/itex]
because the 4-velocity is purely temporal, in that comoving rest frame. So that implies that:
[itex]U^\mu D_\mu \delta \lambda + U^\mu U_\mu \delta \tau = 0[/itex]
Since [itex]U^\mu U_\mu = 1[/itex] for any object (in units with c=1), it follows that:
[itex]\delta \tau = - \delta \lambda \ U^\mu D_\mu[/itex]
This is the value of [itex]\delta \tau[/itex] that makes [itex]\mathcal{P}(\lambda, \tau)[/itex] and [itex]\mathcal{P}(\lambda + \delta \lambda, \tau + \delta \tau)[/itex] simultaneous, in the comoving rest frame of the string at label [itex]\lambda[/itex]. So for this value of [itex]\delta \tau[/itex], the separation between the nearby pieces of string is given by:
[itex]S^\mu = \delta \lambda (D^\mu - (U \cdot D) U^\mu)[/itex]
If there were no stretching or compression, then the separation between the two points would be of magnitude [itex]\delta \lambda[/itex]. So a measure of the stretching or compression is the factor:
[itex]Q = - \frac{S_\mu S^\mu}{\delta \lambda^2}[/itex] (the minus sign is because the square of a spatial vector is negative, in my convention)
If there is no stretching or compression, then [itex]Q = 1[/itex]. If [itex]Q > 1[/itex], that means the string is being stretched. If [itex]Q < 1[/itex], that means the string is being compressed.
So writing it out,
[itex]Q = - (D^\mu D_\mu - (D^\mu U_\mu)^2)[/itex] (where I again used [itex]U^\mu U_\mu = 1[/itex])
Just as a check, if every part of the string is at rest in Rindler coordinates, then that means
[itex]x(\lambda, \tau) = \lambda cosh(\frac{\tau}{\lambda})[/itex]
[itex]t(\lambda, \tau) = \lambda sinh(\frac{\tau}{\lambda})[/itex]
(The usual Rindler coordinates use [itex]X, T[/itex] instead of [itex]\lambda, \tau[/itex]. The relationship is just [itex]\lambda = X[/itex], [itex]\tau = \lambda gT[/itex])
then [itex]Q = 1[/itex] (I'm skipping the proof). So if the string is at rest in Rindler coordinates, then it is unstretched.
On the other hand, if every part of the string accelerates together at the rate, then:
[itex]x(\lambda, \tau) = \lambda + f(\tau)[/itex]
[itex]t(\lambda, \tau) = g(\tau)[/itex] (independent of [itex]\lambda[/itex].
Then
[itex]Q = 1 + U^2[/itex]
where [itex]U = \frac{dx}{d\tau}[/itex]
So [itex]Q > 1[/itex]. So if the points on the string are undergoing simultaneous acceleration, then the string stretches.
Mentz114
- 5,429
- 292
stevendaryl said:I'm sorry, did you already define θ\theta? The way you've defined it seems to treat ubu_b as a vector field, but how is that defined?
Yes, ##u## is a congruence (time-like vector field). I skipped a lot of detail because I wanted to keep it simple. It is fully covariant. It is done in the global frame basis where partial differentiation is covariant. I can repeat it in the local frame and (of course) get the same result.
It'll take time to understand your workings above.
- 26,403
stevendaryl said:did you already define ##\theta##? The way you've defined it seems to treat ##u_b## as a vector field, but how is that defined?
##\theta## is just the expansion scalar; it's part of the kinematic decomposition of the timelike congruence ##u_b##. See here:
http://en.wikipedia.org/wiki/Congru...atical_decomposition_of_a_timelike_congruence
What you are doing in the rest of your post is basically the same thing, just with different notation. The key is that the kinematic decomposition is frame-independent; you can compute it in any frame you like, but the scalars derived from it, such as the expansion scalar, are invariant. So the expansion scalar of the Bell congruence being positive is a frame-invariant way of saying that the string stretches.
harrylin
- 3,874
- 93
That was exactly Bell's point! He simply stayed in S to obtain the answer and while that's perhaps a bit subtle, his method is not difficult or complicated. And it looks much simpler to me than your method.Mentz114 said:[..] The fact that people are using comoving frames to decide questions of physics and not getting clear answers makes me think those methods are very subtle and difficult to use. So, complicated and not needed for understanding. [..].
Mentz114
- 5,429
- 292
harrylin said:That was exactly Bell's point! He simply stayed in S to obtain the answer and while that's perhaps a bit subtle, his method is not difficult or complicated. And it looks much simpler to me than your method.
I'm not sure what you're calling 'you're method'. If you mean the expansion scalar, then I cannot take credit for that. It's a standard kinematic decomposition found in textbooks.
As for the 'explanations' why an apparently unstretched string snaps they all seem to be flawed because there is no way to define (unambiguously) a time-independent length of an object if the clocks along its length cannot be synchronised. So any object in this condition cannot, by definition, have a constant length because the length is different at every measurement ( I think stevendaryls calculatation reinforces this).
Using some bogus definition of distance it is easy to conclude that there is something to explain - but there isn't.
- 4,227
What do you mean by "bogus "? In the initial rest frame you have a ruler at rest and synchronized clocks placed along it. You can easily measure where the ends of the string are at any time point, and thus what the length of the string is, according to that frame.Mentz114 said:Using some bogus definition of distance it is easy to conclude that there is something to explain - but there isn't.
harrylin
- 3,874
- 93
Well of course, we all know the string will increasingly come under strain. But when Bell first presented this example, many people at CERN gave the wrong answer ("There emerged a clear consensus that the thread would not break!"). That was almost certainly due to wrong and perhaps overly complicated reasoning. In contrast, Bell's physical analysis is as simple and easy as it can get, and it gives the right answer. Therefore he included it in his paper "How to teach relativity".Mentz114 said:[..] As for the 'explanations' why an apparently unstretched string snaps they all seem to be flawed [...].
Mentz114
- 5,429
- 292
A.T. said:What do you mean by "bogus "? In the initial rest frame you have a ruler at rest and synchronized clocks placed along it. You can easily measure where the ends of the string are at any time point, and thus what the length of the string is, according to that frame.
But the clocks on the ends of the ruler are not synchronised with the string clocks. So measuring them simultaneously ( in S) is not simultaneous in the ship frame.
I think StevenDaryls approach overcomes this, at the cost of producing a length measure which cannot remain the same. He works out a frame independent length which is based on proper time.
- 4,227
Yeah, but it gives you a perfectly valid length measurement in S. I don't understand what is "bogus" about it.Mentz114 said:So measuring them simultaneously ( in S) is not simultaneous in the ship frame.
harrylin
- 3,874
- 93
And there is absolutely no need to look at what is simultaneous in S'.Mentz114 said:But the clocks on the ends of the ruler are not synchronised with the string clocks. So measuring them simultaneously ( in S) is not simultaneous in the ship frame. [..]
Bell's approach is quite similar to Einstein's approach when he made the first clocks prediction: first he worked out, based on the Lorentz transformations, what according to S the rate is of a clock in motion. That yielded a new law of physics about moving clocks. Based on physical reasoning he then predicted the retardation of a clock that moves at constant speed in a circle, without needing any more Lorentz transformations.
(once more: §4 of http://www.fourmilab.ch/etexts/einstein/specrel/www/ )
Imagine that we next slightly complicate Einstein's example, in the spirit of the title of this thread, by having two identical clocks that are located at a distance from each other depart simultaneously, with identical acceleration profiles.
Following Einstein and Bell, it "is at once apparent" that they will remain in synch with each other according to clocks at rest in S; and that they will delay, compared to clocks in S, by the same amount.
In contrast, if one feels the need to continuously transform to instantaneous rest frames S' and S''(etc) of the moving clocks and next compare the moving clocks with each other from consecutive S' and S'', a complicated calculation follows from which one learns nothing new and that yields the same result - if no error is made.
Mentz114
- 5,429
- 292
harrylin said:Well of course, we all know the string will increasingly come under strain. But when Bell first presented this example, many people at CERN gave the wrong answer ("There emerged a clear consensus that the thread would not break!"). That was almost certainly due to wrong and perhaps overly complicated reasoning. In contrast, Bell's physical analysis is as simple and easy as it can get, and it gives the right answer. Therefore he included it in his paper "How to teach relativity".
Thanks. So the ship clocks are out of synch by the same amount with the ruler clocks. I just want to summarise the gist of the 'explanation'.harrylin said:And there is absolutely no need to look at what is simultaneous in S'.
In the stationary frame basis every ship has the same velocity and acceleration, and the gap between them remains the same. But the string gets tighter and breaks.
So a force field of the EM type is proposed that has this effect on matter. Now the force field must increase so it cannot depend on the acceleration which is constant. It must therefore depend only on the velocity of the ships as measured in the ground frame. Now suppose the acceleration is zero - the same conditions hold as previously.
Why does the string not snap ?
(This is a bit obvious so I must have overlooked something ).
[edit]
The 'effect' obviously can depend on the magnitude of the acceleration. Getting late here. Apologies.
- 4,227
Yes, since the length didn't change, the only explanation why the stress increases is that the stress-free-length, that the string tries to reach has changed.Mentz114 said:In the stationary frame basis every ship has the same velocity and acceleration, and the gap between them remains the same. But the string gets tighter and breaks.
The interactions between atoms are EM.Mentz114 said:So a force field of the EM type is proposed that has this effect on matter.
Not just increase everywhere, but contract along the direction of motion of its source. This can lead to increased forces along that direction, even if the interacting atoms keep a constant distance.Mentz114 said:Now the force field must increase...
Yes, length contraction depends on velocity.Mentz114 said:It must therefore depend only on the velocity
harrylin
- 3,874
- 93
That's perhaps a bit putting the cart before the horse. If atomic bonds are electromagnetic, then EM laws should make predictions that agree with the relativity principle. And apparently this is the case with Maxwell's laws (it's not simple though).Mentz114 said:Thanks. So the ship clocks are out of synch by the same amount with the ruler clocks. I just want to summarise the gist of the 'explanation'.
So a force field of the EM type is proposed that has this effect on matter. [..]
From the Lorentz transformations, Einstein (re-)derived the following laws of physics:
- a clock that is brought in motion will tick slower than in rest by the factor gamma (ceteris paribus)
- a ruler that is brought in motion will contract by the factor gamma (ceteris paribus)
Those laws should not be confounded with the Lorentz transformations. But they look very similar, and "length contraction" and "time dilation" similarly can have two meanings. It is increasingly my opinion that lack of distinction between the Lorentz transformations and the new laws of nature that followed from them is the main cause of why "paradoxes" with clocks and rulers continue to bug people.
To state clearly what is often brushed over:
1. SR's Lorentz transformations. Positions and distances as well as times and time periods as measured in different inertial frames are mapped to each other by means of the Lorentz transformations. This is valid between two inertial reference systems (with "Einstein synchronization").
2. Some of SR's laws of nature. The frequencies and lengths of objects (clocks and rulers) depend on their speed. This is valid for objects in any state of motion in a single inertial reference system (by a single "observer"). Of course, the effects of other physical influences must also be taken in account.
BTW the use of the "observer" short-hand only helps to forget that it does not mean objects or people. Even "frame" can be misleading in a similar way.
When mixing up these very different but similar looking notions, one could for example wrongly think that:
- the Lorentz transformations may be used for the accumulated time of an inertial clock according to an "observer" in any state of motion - the modern version of the "twin paradox".
- a non-connected system of accelerating rockets will contract as a whole - the Bell spaceship paradox.
- an accelerating system with clocks will naturally maintain Einstein synchronization (posts 1 and 8).
PS. question to 1977ub: was something like that also the reason for your confusion, or was there a different cause?
bligh
- 14
- 0
I like the thought exper of two clocks, one stays, the other acclerated to the front. stays one year and then acclerated to the rear.
But, this non stationary clock would have had it's time "dilated" during two accelerations and would therefore show less time elapse, not more as you
suggested.
Correct?
suggested.
Correct?
bligh
- 14
- 0
although time dilatation in accelerated clocks is well accepted, no one has shown length contraction in real life.
Correct?
Correct?
- 13,790
- 16,583
Depends what you mean. There is no way to explain the cosmic ray muons without length contraction, and the explanation for the motion of a charge near a current carrying wire needs it, too.bligh said:although time dilatation in accelerated clocks is well accepted, no one has shown length contraction in real life.
Correct?
However, no one has ever shut a 1m pole into a 0.5m barn, if that's what you mean.
- vanhees71
- · Replies 42 ·
- Special and General Relativity
- Replies
- 42
- Views
- 8K
High School
Bell spaceship paradox - qualitatively
- Dadface
- · Replies 21 ·
- Replies
- 21
- Views
- 4K
- bcrowell
- · Replies 27 ·
- Replies
- 27
- Views
- 4K
- mananvpanchal
- · Replies 16 ·
- Replies
- 16
- Views
- 6K
