Closed tube standing wave
Standing waves in a closed tube produce a fundamental frequency based on the tube's length, calculated as v/4L. In an experiment with a 33.2 cm bottle, the expected frequency was 283 Hz, but spectral analysis revealed a fundamental frequency of 96 Hz with harmonics. This discrepancy is attributed to the bottle acting as a Helmholtz resonator rather than a simple closed-end pipe. Switching to a proper pipe confirmed the expected frequency, aligning with the Helmholtz resonant frequency calculation. The experiment highlights the importance of understanding the differences between resonator types in sound production.
exaramco
Standing waves have a fundamental frequency equal to 4x the length of the pipe if the pipe is closed at one end and open at the other end.
So, blowing across the top of a 33.2 cm bottle should produce a fundamental frequency of v/4L or about 340/1.2= 283 hz. When I record the sound produced by this bottle and then run a spectral analysis (I have done this several times) sampling at both 1000 hz and 44khz I consistently get a fundamental frequency of 96 hz with harmonics at multiples of 96 hz. A closed end tube should produce only odd harmonics.
What is going on?
A bottle is not a pipe.
A bottle often works as a Helmholtz resonator.
This is probably what happened in your experiment.
Right you are! I changed to a pipe and the spectrum came right on target. Thank you.
In fact, when I plugged in the equation for the resonant Helmholts frequency, it came at about 100 hz--just what I measured. Thanks again.
