Are These Sets of Matrices Closed Under Multiplication?
summer
A set S of (necessarily square) matrices is said to be closed under multiplication if AB∈ S whenever A, B ∈ S.
Which of these matrices are closed under multiplication?
Circulant matrices
Upper triangular matrices
Hessenberg matrices
My trouble: How do I go about figuring this one out?
"A set S of (necessarily square) matrices is said to be closed under multiplication if AB∈ S whenever A, B ∈ S."
Perhaps you mean that the multiplication of 2 matrices of the same type will give as result a matrix of the same type.If that's so, then all triangular matrices are closed under multiplication (it can be proved, just have to use the definitions of triangular matrices and matrix pultiplication).
I'm not familiar with the other types os matrices.
Best regards
you mean "which of these sets of matrices is closed under multiplication".
If you multiply two circulant matrices is the result always a circulant matrix?
If you multiply two Hessenberg matrices is the result always a Hessenberg matrix?
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
