What Initial Current Flows When S is Closed in a P241B Coaxial Cable Circuit?
The discussion focuses on the initial current flow in a P241B coaxial cable circuit when a switch is closed. The effective resistance of the cable is calculated to be 150 ohms, combining the cable's resistance and a 50-ohm resistor. At time t=0, the current is zero due to the inductor's effect, while at t=infinity, the current also approaches zero because of the capacitor. The second part of the problem involves applying Kirchhoff's Voltage Law (KVL) to derive a differential equation for the circuit. The conversation highlights confusion regarding solving the differential equation and whether alternative methods may be applicable.
mathman44
Type P241B coaxial cable has an inductance of 0.4 μH/m and a capacitance of 40 pF/m.
The diagram below shows a 100 m length of this cable connected to a battery and switch at the sending end and a 50Ω resistor at the receiving end.
(a) If S is closed, what initial current will flow from the battery?
(b) How long will it take before this current changes?
(c) What will be the battery current at t=∞?
I calculated the effective resistance of the cable to be 100 ohms. Since this is in series with a 50 ohm resistor then the total resistance is 150.
does this sound reasonable?
a) at t=0 current is zero because of inductor
b)
c) at t=infinity current is zero again because of capacitor
I'm stuck on B :s
Hah, yeah, you got the easy parts right :p
The other part is simply KVL: add up all the potentials going along the circuit to get your differential equation, and then solve the ODE. Depending on how complex your class is, you may need to solve simultaneous ODEs.
Thanks for the response! I don't think I know what you're talking about for the second part, though... at any rate, it doesn't relate to our class material. Might there be another way to solve this?
