Coefficient of Kinetic Friction physics
To find the coefficient of kinetic friction for the bank safe being pushed and pulled, the forces acting on it must be analyzed. The safe, weighing 300 kg, moves at a constant speed, indicating that the net force is zero. The total horizontal force applied is 385 N from Clyde and 350 N from Bonnie, leading to a combined force of 735 N. The frictional force opposing this motion equals the applied force, allowing the coefficient of kinetic friction to be calculated using the formula f_friction = μ_k * N, where N is the normal force. Understanding the relationship between constant velocity and friction is crucial for solving the problem accurately.
Chaoticsouls
Physics problem - coefficient of friction? Bonnie and Clyde are sliding a 300 kg bank safe across the floor to their getaway car. The safe slides with a constant speed if Clyde pushes from behind with 385 N of force while Bonnie pulls foward on a rope with 350N of force. What is the safe's coefficient of kinetic friction of the bank floor?
I'm guessing f=ma?
2.0x10? What I did was use the formula and drew out the picture and tried to solve the problem. I ended up getting confused on which formula to use and how to go about solving it.
Nope, that's not the correct formula. How would you find the coefficient of friction using a formula that doesn't even mention the coefficient of friction? There's a formula for the force due to friction that has something to do with the coefficient of friction. Look for that formula. Also, the problem mentions "constant velocity" - what do you know about constant velocity?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
