Coefficient of Kinetic Friction
The discussion revolves around a physics problem involving a 5.20 kg block moving up an inclined plane. The change in kinetic energy was calculated as -154.154 J, and the change in potential energy was found to be 75.6 J. The frictional force acting on the block was determined to be 26.18 N. The coefficient of kinetic friction was initially miscalculated as 3.327 due to a calculator error, but it was clarified that the correct value is approximately 0.59 after correcting for radians. The conversation highlights the importance of ensuring calculator settings are accurate when performing physics calculations.
yb1013
A 5.20 kg block is set into motion up an inclined plane with an initial speed of v0 = 7.70 m/s. The block comes to rest after traveling 3.00 m along the plane, which is inclined at an angle of 30.0° to the horizontal.
(a) For this motion, determine the change in the block's kinetic energy.
I got -154.154 (correct)
(b) For this motion, determine the change in potential energy of the block-Earth system.
I got 75.6 (correct)
(c) Determine the frictional force exerted on the block (assumed to be constant).
I got 26.18 (correct)
(d) What is the coefficient of kinetic friction?
However, I could not figure this out for the life of me. Please help with the kinetic friction?
I think the coeff. can be found with f=μmgCosθ , however my answer keeps coming out wrong...
after using the previous formula, I came out with a value of μ=3.327 (26.18=u(5.2)(9.81)(cos(30))
is the answer .59?
I don't understand how you get 3.327... coefficiant of friction isn't going to be more than 1
if you calculate what you have
u get
26.18=44.13u
divide by 44.13
=.59
oooooo haha, thank you sir, my calculator somehow reverted itself back to radians?
Thanks again!
Thanks again!
no prob. you did all the hard work haha
