Coherent states of a Quantum Harmonic Oscillator
Piano man
Given that
a^+|n\rangle=\sqrt{n+1}|n+1\rangle
a|n\rangle=\sqrt{n}|n-1\rangle
and that the other eigenstates |n> are given by
|n\rangle=\frac{(a^+)^n}{\sqrt{n!}}|0\rangle
where |0> is the lowest eigenstate.
Define for each complex number z the coherent state
|z\rangle=e^{-\frac{|z|^2}{2}}\sum^\infty_{n=0}\frac{z^n}{\sqrt{n!}}|n\rangle
Q. Show that |z> is an eigenstate of a:
a|z\rangle=z|z\rangle (\text{Hint: use } |n=-1\rangle=0)
2. The attempt at a solution
I've tried subbing in a few things but have got nothing substantive.
I would really appreciate if someone could point me in the right direction.
So, you are told how the a operator acts on the state |n>. Using this info, if you explicitly work out a|z>, what do you get? I need to see some work to see where you're stuck.
okay well I'm not sure if I should go back to the definition of a, which was
a=\frac{ip+mwx}{\sqrt{2m\hbar w}}
or apply
a|n>=\sqrt{n}|n-1> giving
\sqrt{n}e^{\frac{-|z-1|^2}{2}}\sum^\infty_{n=0}\frac{(z-1)^n}{\sqrt{n!}}|n>
but neither approach is yielding anything useful.
(I'm sorry about the formatting of this, but the tex commands aren't coding properly for whatever reason.)
Maybe I can try posting the latex? :
a|n>=\sqrt{n}|n-1>
OK. Your approach in writing equation 3 is correct, but you have one important error:
Look at equation 2: <br /> a|n&gt;=\sqrt{n}|n-1&gt;<br />
Now if you apply the above to equation 3: |n&gt;\rightarrow|n-1&gt; not z^n\rightarrow(z-1)^n
The operator a, does not affect the complex number z^n. After you change this, see how far you can get.
HINT: After you simplify you'll have to change the limits on the sum to get a|z> to look like |z>. It is in this step that you make use of the hint they gave you.
right, so
a|z>=\sqrt{n}e^{\frac{-|z|^2}{2}}\sum^\infty_{n=0}\frac{z^n}{\sqrt{n!}}|n-1>
(again, sorry about the display, for some reason every time I use the wraps it just gives the first equation I wrote in the OP)
a|z&gt;=\sqrt{n}e^{\frac{-|z|^2}{2}}\sum^\infty_{n=0}\frac{z^n}{\sqrt{n!}}|n-1&gt;
edit: okay it's working now. I think it's just the preview post that isn't working.
so where can I go from here?
Ah! I got it, thanks a million for your help :D
Sorry, I haven't responded! Been at a conference all day today. Glad you figured it out!
