Applying to MIT: What GPA is Necessary?
  • Thread starter Thread starter The_oMeGa
    Gpa Mit
For applicants to MIT, a GPA of around 3.78 is generally considered competitive, especially when combined with strong ACT scores like 33. While GPA and standardized test scores are important, they primarily serve as initial filters for admissions. The admissions process also heavily weighs subjective elements such as letters of recommendation, extracurricular activities, and personal essays. Excelling in math and science can further enhance an applicant's profile. Overall, a well-rounded application that highlights strengths beyond academics is crucial for standing out.
The_oMeGa
Any of you in/applying to MIT? I was wondering... I have read tons of reviews and the statistics say that the average ACT is 31... But what kind of GPA is necessary? I made a 33 on the ACT, but my GPA is only about 3.78. I accel in math and science... but I don't know what their expectations are grade wise.
3.78 (out of 4?) is nothing to be ashamed of and certainly nothing that will cost you admission (especially if your science and math grades are higher). I don't know much about the ACT, but if your scores are above average, that's a point in your favor. Try to represent yourself well in your interview; focus on your strengths. In general, GPA (usually relative to your class) + board scores will serve as a weed-out test (which I would guess you would pass) to determine if you can handle the pace. From there, final decisions will be based on your supporting materials (e.g. references, interview, extra-curricular, and essays).
What's really underestimated is how significant the letters of recommendation and extracurricular activities are. Most people that apply to MIT have really good test scores and grades. What gets you noticed is the more subjective things.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
