Collision between a steel plate and meterstick in frame S?
  • Thread starter Thread starter mntb
    Collision
The discussion centers on the collision dynamics between a moving steel plate with a circular hole and a meterstick in a relativistic framework. The steel plate, moving in the +y direction at speed v, does not experience a relativistic change in the diameter of its hole. In contrast, the meterstick, moving in the x direction at speed v/c, undergoes length contraction. The conclusion is that there will be no collision between the two objects as they reach the same point simultaneously, despite the relativistic effects on the meterstick.
  • Understanding of special relativity principles
  • Familiarity with length contraction and relativistic effects
  • Knowledge of coordinate transformations in relativistic physics
  • Basic concepts of motion in multiple dimensions
  • Study the implications of length contraction in special relativity
  • Learn about coordinate transformations in relativistic physics
  • Explore the concept of simultaneity in different reference frames
  • Investigate scenarios involving collisions in relativistic contexts
Students and professionals in physics, particularly those studying special relativity, as well as educators looking to illustrate relativistic effects in motion and collision scenarios.
mntb
A very thin steel plate with a circular hole one meter in diameter centered on the y-axis lies parallel to the xz plane in frame S and moves in the +y direction at constant speed v, a mterstick lying on the x-axis moves in the x directoin with v/c.The steel plate arrives at the y=0 plane at the same instant the center of the meterstick reaches the origin of S. Will there be a collision?
Not all that paradoxical. The steel plate (more specifically, the hole) moves in the y-direction so there is no relativistic change in the diameter of the hole. The meter stick is moving in the x direction so there is contraction. By the way, (although it doesn't affect the answer) are you sure about that "with v/c"? Was that "with speed v/c"? In that case, what are the units?
yeah, but if you see it in the meter stick' coordinate, then the steel plate does have a relativisic change: it moves in the x direction
  • · Replies 31 ·
  • · Replies 20 ·
