Collision with Spring: Solving for Distance and Final Velocities
  • Thread starter Thread starter kle89
    Collision Spring
To solve the problem of a moving block colliding with a stationary block and spring, the maximum compression of the spring can be determined using energy conservation principles, where the kinetic energy of the moving block is converted into potential energy stored in the spring. The equation 1/2mv^2 = 1/2kx^2 can be used, but the final velocity after the collision must be calculated first. For part b, conservation of momentum is applicable, as both blocks stick together post-collision, allowing for the calculation of their final velocities. It is suggested to analyze the scenario from the center of mass frame for a clearer understanding of the interactions. The initial velocity of the first block can be assumed to remain at 8 m/s at the moment of spring contact.
kle89
Problem
One block (3kg) is moving at 8m/s on a frictionless plane to collide with another block at rest with the same mass, but has a spring in front of it. Spring constant = 6 N/m
a. Determine the maximum distance the spring is compressed.
b. Determine the final velocities of the blocks after the collision. You should assume that the 1 kg and 2 kg blocks remain stuck together.
Honestly i have no idea how to set the equation up? Would i use 1/2mv^2' = 1/2kx^s + 1/2mv^2 to find the distance of the spring? The problem is i wouldn't know what the final velocity would be after hitting the spring so i can't solve exactly for x. Also the other block with the spring could move after the collision so wouldn't its velocity be equal to that of the original block after hitting the spring but in the opposite direction? Any hints to get me on the right track would be appreciated. Thanks in advance.
maybe you can assume that at the point where the 1st block contacts the spring of the 2nd block, the velocity of the 1st block is still 8 m/s... Then you can just look focus on the time frame in which the whole spring compression occurs, knowing that the initial velocity of the 1st block when it contacted the spring was 8m/s.
Part b would most probably involved conservation of momentum law. But you need to solve a.
use center of mass frame!
