Combination W-K problem with spring
  • Thread starter Thread starter itsvt2013
    Combination Spring
The problem involves a 2 Kg slider A compressed against a spring (k=900) by 0.4m, which is released to slide down a 5m ramp with negligible friction. To find the velocity of the 3 Kg slider B after an elastic collision, the energy stored in the spring and kinetic energy equations are utilized. The initial velocity of slider A is calculated using the spring's potential energy, followed by determining its acceleration down the ramp. The final velocity of slider B after the collision is expected to be 8.8 m/s. The solution emphasizes the application of energy conservation and collision principles to solve the problem.
itsvt2013
The 2 Kg slider A is held at rest against the spring k=900 compressing the spring by 0.4m. It is released and slides down the 5 m long ramp. Friction is negligible along the track. Slider A then makes an elsastic collision with the 3Kg slider B that is initially at rest. Find the velocity of slider B right after the collision.
I used w-k equation then elastic collision to find V'B
The answer suppose to be 8.8
Start by using the formulas for energy stored in a spring and kinetic energy. Use these to calculate initial velocity. Then find out how much it accelerates down the ramp.
