Combinatorics: Generating functions
BrownianMan
I have that B(x)=e^{e^{x}-1} is the generating function for the number of set partitions. Also the Stirling numbers of the second kind are de fined by S(0,0)=1, S(n,0)=S(0,n)=0 for n=>1 and S(n,k)=S(n-1, k-1) + kS(n-1, k). Show that
e^{u(e^{x}-1)}=1+\sum_{n\geq 1}\sum_{k=1}^{n}S(n,k)u^{k}\frac{x^{n}}{n!}
Use this result to show that
S(n,k)=\frac{1}{k!}\sum_{r=0}^{k}(-1)^{k-r}\left \binom{k}{r}r^{n}
I've tried doing this but I cannot seem to get very far. Could someone show me how to prove this? Thanks.
So
e^{u(e^{x}-1)}=B(x)^u
If you write that out using the definition of B(x), collecting up the coefficients of xn will, with luck, produce:
\frac{1}{n!}\sum_{k=1}^{n}S(n,k)u^{k}
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
