Combinatorics: Linear Code Proof
Askhwhelp
Consider S ={0120, 1010, 2011} as a subset of codes of length four over Z3 with d = 3 By (a) Show that S is a linearly independent set.
I am asked to show S is a linearly independent set. However, if I add 0120 + 0120, I get 0210. Since 0210 is not in the set S, is S still a linearly independent set. If so, how could I show it?
Yes, the property you have in mind is called "closed" - indeed S is not closed (under the operation).
Linearly independent means that you cannot express any of the codes as a linear combination of one of the others. In other words, if you would write
$$a [0120] + b [1010] + c [2011] = [0000]$$
for integers ##a##, ##b## and ##c##, then the only solution to the above equation would be ##a = b = c = 0##.
Likes 1 person
A follow up question:
Let S be a basis for a linear code C. How many code
words does C have? Justify your answer.
I have no clue how to go about it
Have you solved your original question yet, then? Because I haven't looked at it further, but I didn't give you the full answer by far.
I found a, b, c = 0...for the follow-up question, is it just 3^3?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
