Combinatorics, probability and statistics Questions
The discussion revolves around three combinatorial and statistical problems. For the seating arrangement of 30 students at 35 desks, the correct approach involves using combinations to select the desks and permutations for the students, leading to the formula 35C30 multiplied by 30!. The handshake problem among 16 people is clarified, noting that the total handshakes can be calculated using the formula n(n-1)/2, resulting in 120 handshakes, rather than factorial calculations. Lastly, for the juice box volume distribution, the mean is correctly identified as 250mL, and the standard deviation is estimated to be around 3mL based on the range provided. These problems highlight fundamental concepts in combinatorics and statistics.
Numbnut247
Hey guys, I have a few questions:
1. There are 35 desks in a classroom. In how many ways can the teacher configure a seating plan for a class of 30 students?
I'm not sure if order matters (35P30 or 35C30).
2. Sixteen people attend a meeting. Each person greets everyone with a single handshake. Find the total number of handshakes that are exchanged.
Each person shakes 15 other people's hand but half of them are repeated so is it (15!)/2
3. A manufacturer determines that the volume of juice in a juice box is normally distributed with a minimum of 244mL and a maximum of 256mL. What is the best estimate of the standard deviation? Complete it without the use of a calculator.
I got 250mL as my mean by (244+256)/2. I'm thinking the minimum and maximum should be about 95 percent of the good so the standard deviation is 3?
Thanks
If you take 35C30, you have the number of ways to pick 30 seats out of 35 (the ones that will be occupied). But for every choice of these 30 occupied seats, every permutation of the 30 students will give a different seating plan.
Phew, 15!/2 is a big big number! If two handshakes would be exchanged every second you'd still be shaking after 10,000 years.
It's true that each person shakes 15 hands and then you count double, but that doesn't lead to 15! (=15*14*13*...*1)
Got it, thanks a lot guys
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
