Compare a series sum to it's equivelent integral
stufletcher
excuse my formatting.
compare
sum(from n=2 -> infinity) of 5/(n^1.1)
to
integral (from 1 -> infinity) of 5/(x^1.1)
if it was sum and integrate from 2 it would be easy... the sum is a rienmann sum using right endpoints and delta-x of 1, and it's error will always be larger than it's integral on a decreasing curve.
however because the function is decreasing, and the integral starts at 1, not 2, i think i have to calculate the size of the error of the rienmann compared to it's integral from 2 -> infinity, and compare that to the integral from 1 ->2.
maybe I'm just having a brain coniption, but i can't seem to sum either the rienmann or the integral from 2 -> infinity... anyone have any suggestions?
thanks
stu
It's easier to see what to do with a simpler function. Let's use 1/x.
Draw a graph, using bars of width 1 to represent each value, so you end up with a bar graph of 1/x. The sum of the area under the bars is the sum of 1/x. Now notice that you can have two curves, one joining up the top left corners of the all bars, and one joining up the top right corners. These curves are 1/x curves, but one of them is shifted along by 1 unit. The area under these curves can be found by integrating 1/x, between appropriate limits. Can you see how to apply this method to your problem?
it's always something simple isn't it..
area \frac{5}{x^{1.1}} * (x - (x-1)) < \int_{x-1}^x\frac{5}{x^{1.1}}dx
for all values of positive x, so the sum must be smaller than the integral
thanks for the tip
stu
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
