Comparing 2 sample means of 2 different samples
  • Thread starter Thread starter cse63146
    Means
The discussion revolves around comparing two sample means to determine if the mean of population 2 is less than that of population 1, using a significance level of alpha = 0.01. A t-test was employed, yielding a p-value of 0.0079, which is statistically significant, leading to the rejection of the null hypothesis. The appropriate null hypothesis is stated as H0: μ1 - μ2 ≤ 0, while the alternative hypothesis is H1: μ1 - μ2 > 0. Additionally, there was clarification on using the correct test statistic and understanding the implications of the results. Ultimately, the findings suggest that the mean of population 2 is indeed less than that of population 1.
cse63146
sample 1: size -10, mean -124, variance -1681
sample 2: size -5, mean -68, variance - 481
Assuming equal variance, independent and normality holds
a)Is there any evidence that that the mean in population 2 is is less than the mean in population 1? Use alpha = 0.01. What is the p-value?
b)Test the 2 variances. Alpha = 0.05
for a), would I use the following test statistict = \frac{\overline{x} - c}{s/\sqrt{n}}~t_{n-1}. Just not sure how to incorporate the 2 different sample variances.
For a), don't you want to test H_0 \colon \mu_1 - \mu_2 > 0? What test statistic is appropriate for that?
For 2 independent Normal samples, with common unknown variance \sigma^2
\frac{(\overline{y}_1 - \overline{y}_2) - (\mu_1 - \mu_2)}{S_p \sqrt{n^{-1}_1 -+n^{-1}_2}} is a t distribution with (n1 + n2 - 2) degrees of freedom.
Where S2p = \frac{(n_1 - 1)S^2_1 + (n_2 -1)S^2_2}{n_1 + n_2 - 2} = 1311.8
Not sure how to use the formula though since I don't know mu1 and mu2
Your complete hypotheses would be (I typed H_0 instead of H_a and > rather than \le at first, sorry)
<br /> \begin{align*}<br /> H_0 \colon &amp; \mu_1 - \mu_2 \le 0 \\<br /> H_a \colon &amp; \mu_1 - \mu_2 &gt; 0<br /> \end{align*}<br />
You don't need to know the actual value of \mu_1 - \mu_2 to use the test statistic: you use the boundary between the two possibilities, which is 0.
H_0 \colon &amp; \mu_1 - \mu_2 = 0
is that another acceptable way to write H0?
No, you want the inequality, since that's what matches your problem statement.
From the quote just above (which represents the alternate hypothesis), the null hypothesis is that
\mu_1 - \mu_2 \leq 0
As you wrote it, the probability of the null hypothesis would be zero.
For some reason I thought that it was asking if there was a difference between the 2 means. My mistake. Thanks.
"the probability of the null hypothesis would be zero."
Not sure what you mean here (that would be the only way to write the null in the case of the alternative being two-sided), but many authors would write H_0 \colon \mu_1 - \mu_2 as H_0 \colon \mu_1 - \mu_2 = 0. It's an odd convention, but it does happen.
My mistake. I was thinking in terms of variables rather than statistics, if that makes any sense. IOW, along these lines: Pr(z = k) = 0.
So I computed the p-value using a t-test, and got the value of 0.0079. Since alpha = 0.01, I can say that the p-value is statistically significant at the 1% level, and I reject the null hypothesis and accept the alternate hypothesis?
That's rather what I thought - but I have learned to be hesitant making assumptions about the posts of others.
I haven't checked your calculations, but if the numbers are correct, so is your final statement. However, "accept the alternative hypothesis" is rarely the form a faculty member or researcher wants as the final answer: if you know that the alternative is to be accepted, you should clearly state what this means about the two population means.
Does this sound better:
At the 1% level, the data provides evidence against the null hypothesis in favour of the alternate hypothesis, which implies that the mean of population 2 is less than the mean if population 1.
