Comparing Series & Parallel Connections of Helmholtz Coils
Connecting Helmholtz coils in series or parallel affects their electrical behavior in relation to the circuit they are connected to. In a static setup, the coils behave like resistors, impacting the current flow and resulting magnetic field. When driven to produce a constant magnetic field, the field remains stable if the current is constant, particularly with identical coils. If the coils are driven by an oscillator, the magnetic field will oscillate in response to the changing current. The choice of connection method ultimately influences the magnetic field's characteristics and stability.
strokebow
Hi,
With the condition that 2 helmholtz coils are parallel with each other sharing the same axis in space . . .
What are the differences between electrically connecting up the coils in series and in parallel?
cheers
That depends on the circuit you connect them to. In a static setup, they are like resistors.
Thanks for your response.
In the case that they are being driven to produce a constant magnetic field between them.
The magnetic field is always constant if the current in coils is constant. And its second derivative vanishes if the coils are identical and have the same current inside.
The absolute value of the magnetic field there depends on that current, and that depends on the electric setup.
Thanks very much.
How would things differ if they were driven by an oscillator?
The magnetic field would oscillate as well.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
