How to Complete the Square: Walkthroughs for Finding Vertex and X-Intercepts
  • Thread starter Thread starter schlynn
    Square
Completing the square is essential for finding the vertex and x-intercepts of quadratic functions. The process involves rewriting the quadratic equation in the form f(x) = a(x-h)² + k, where (h, k) represents the vertex. Walkthroughs demonstrate how to handle cases when the leading coefficient, "a," is either 1 or not equal to 1, using specific examples like g(x) = x² + 6x - 120 and h(x) = 3x² + 12x - 111. The vertex can be calculated using the formula (-b/2a, c - (b²/4a)), and intercepts can be found by setting the completed square equal to zero. Understanding these steps is crucial for solving quadratic equations effectively.
schlynn
I need to know how to complete the square, I need to know how to do this to get
(this is to find the vertex of the quadratic function and the x intercept(s)
f(x)=aX2+bX+c to f(x)=a(x-h)2+k
It would be helpfull to see walkthroughs for when a=1 and when "a" does not equal 1.
questions:
-3x2+9x+(1/4)
and
x2-6x-2
I don't think there's any, just that to get y set x=0 and to get x set y=0, for the intersepts that is.
h=horizontal shift in the graph
k=verticle shift in the graph
there is this shortcut too...
f(x)=a(x-h)2+k
and the vertex will be
((-b/2a),c-(b2/4a))
Well, I'm learning this all out of school, and the book doesn't really explain how to do this very well, so I have no idea what do to. Could someone make walkthroughs on how to solve both of the question? This will help me tremendusly as I have been stuck on what to do now.
Here's a quadratic with leading coefficient one.
<br /> g(x) = x^2 + 6x -120<br />
  • Here b = 6. Start by calculating half it
    <br /> \frac b 2 = 3<br />
  • Add and immediately subtract the square of 3, as shown here. (I've grouped the terms
    together for easier reading.) This changes the look of the right-hand-side, but since 9-9=0,
    no numerical change has occurred
    <br /> g(x) = \left( x^2 + 6x + 3^2 \right) - 3^2 - 120<br />
  • The portion in parentheses is (x-3)^2, so we have
    <br /> g(x) = (x-3)^2 - 129<br />
  • The vertex is the point (3,-129). The final step is to find the intercepts.
    <br /> \begin{align*}<br /> (x-3)^2 - 129 &amp; = 0\\<br /> (x-3)^2 &amp; = 129 \\<br /> x-3 &amp; = \pm \sqrt{\, 129} \\<br /> x &amp; = 3 \pm \sqrt{\, 120}<br /> \end{align*}<br />
    The intercepts are (3 \pm \sqrt{\, 129}, 0 ).
For the second question
<br /> h(x) = 3x^2 + 12x - 111<br />
Here is the work to complete the square.
<br /> \begin{align*}<br /> h(x) &amp; = 3x^2 + 12x - 111 \\<br /> &amp; = 3 \left(x^2 + 4x \right) - 111\\<br /> &amp; = 3 \left( \left(x^2 + 4x + 2^2\right) - 2^2 \right) - 111 \\<br /> &amp; = 3 ((x+2)^2 - 4) - 111 \\<br /> &amp; = 3(x+2)^2 - 12 - 111 = 3(x+2)^2 - 123<br /> \end{align*}<br />
The vertex is the point (-2, -123). To find the intercepts
<br /> \begin{align*}<br /> 3(x+2)^2 - 123 &amp; = 0\\<br /> 3(x+2)^2 &amp; = 123\\<br /> (x+2)^2 &amp; = \frac{123} 3 = 41\\<br /> x+2 &amp; = \pm \sqrt{\, 41}\\<br /> x &amp; = -2 \pm \sqrt{\, 41}<br /> \end{align*}<br />
The two intercepts are (-2 \pm \sqrt{\, 41}, 0).
[*] The portion in parentheses is (x-3)^2, so we have
[*] The vertex is the point (3,-129).
Just a minor sign error there, Statdad.
ax^2 + bx + c = a(x^2 + \frac{b}{a} + \frac{c}{a})
ax^2 + bx + c = a((x + \frac{b}{2a})^2 +\frac{c}{a})- \left[\frac{b}{2a}\right]^2
ax^2 + bx + c =a(x + \frac{b}{2a})^2 - \left[\frac{b}{2a}\right]^2 + c
Vertex for any function like
(x+a)^2 + b= \left[\stackrel{-a}{ b}\right]
The reason for this is because for the function to be at its lowest value, given that the first part is squared it has to be equal to 0. The x value for this co-ordinate therefore has to be the negative of a. b is more obvious.
Intercepts
You can do this two ways (assuming that because you have completed the square therefore you cannot factorise) using the quadratic formula or an easier way, manipulating the completed square you have.
(x+a)^2 - b = 0
(x+a)^2 = b
(x+a) = \sqrt{b}
x = -a \pm \sqrt{b}
What if b is positive
(x+a)^2 + b = 0
If b is positive then there is no solution for the function = 0. This is because (x+a)^2 does not intersect the x-axis but touches it at (-a,0). Any increment to such a function will not have real roots.
You can prove this using the discriminant of the quadratic b^2 - 4ac.
Edit:
-3x^2+9x+\frac{1}{4}
1. Take out the -3 for all the expressions
2. Now complete the square within the brackets remembering that the co-efficient of x, b is now actually \frac{b}{a} and becomes \frac{b}{2a}.
ax^2 + bx + c = a((x + \frac{b}{2a})^2 +\frac{c}{a}) - \left[\frac{b}{2a}\right]^2
3. You can now muliply the constant out to get.
x^2-6x-2 You will be able to do now.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
