Complex amplitude reflectance of a spherical mirror
semc
Prove the complex amplitude reflectance of a spherical mirror is given as exp[-jk(x2+y2)/R]
Transmittance of a spherical mirror is also exp[jk(x2+y2)/2f]
I have totally no idea how to go about doing this. Can I just say that the reflectance is the same as the transmittance just that the wave changes the direction of propagation?
I realize this is late but here it goes:
See how much phase you accumulate, relative to the plane wave that travels along the optical axis and bounces off a planar mirror.
If you are looking at the plane wave ##\rho = \sqrt{x^2+y^2}## away from the axis in the plane ##z=0## (mirror centre is at ##z=R## ), then to get to the mirror you need to travel additional distance ##d##. Denote ##z_0## the z at which the ray intersects with the mirror at a given ##\rho##.
$$d = z_0 = R - \sqrt{R^2 - \rho^2} = R - R\sqrt{1-(\frac \rho R)^2}$$
Assuming ##\rho## is small (we are close to the axis) compared to R, we can write
$$\sqrt{1-(\frac \rho R)^2} = 1-\frac {\rho^2} {2R^2}$$
and so
$$d = \frac {\rho^2} {2R}$$
Because we traverse that distance twice, the phase gained is ##k*2d = k \frac {\rho^2} {R}## and your complex reflectance is ##e^{ik \frac {\rho^2} {R}}##
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
