Complex analysis, taylor series, radius of convergence
The discussion revolves around finding the Taylor series and Laurent series for the function f(z) = 1/(1+z^2), with a focus on determining the radius of convergence and the appropriate series representations for different regions in the complex plane.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the radius of convergence, identifying it as 1 based on the points where f(z) is not analytic. There are suggestions to factor the denominator and use partial fractions to facilitate finding the series. Questions arise about how to apply Taylor series expansions to the resulting fractions.
Some participants have provided guidance on using geometric series and partial fractions, while others express confusion about the application of these methods. Multiple interpretations of how to proceed with the series expansions are being explored, but there is no explicit consensus on the next steps.
Participants are navigating the constraints of homework rules, particularly regarding the need to find series representations within specified radii and the implications of the radius of convergence on the Laurent series.
nugget
For f(z) = 1/(1+z^2)
a) find the taylor series centred at the origin and the radius of convergence.
b)find the laurent series for the annulus centred at the origin with inner radius given by the r.o.c. from part a), and an arbitrarily large outer radius.
for a) (sum from j = 0 to infinity)
f(z) = [itex]\Sigma[/itex] [(f[itex]^{j}[/itex](0))[itex]\div[/itex](j!)] [itex]\times[/itex] z[itex]^{j}[/itex]
for b) laurent series formula?
From what I understand, the radius of convergence is from Zo (in this case, the origin) to the closest point where f(z) isn't analytic. f(z) isn't analytic at i or -i. This function is a circle, discontinuous at i and -i. So, by inspection(?), the r.o.c. should be 1.
I don't get how to input the information I have into the formula for a). I think that in understanding this, finding the laurent series should be simplified.
Thanks
Indeed, the radius of convergence is 1.
To find the Taylor/Laurent series; I suggest you factor the denominator first and split into partial fractions. Then you should use
[tex]\frac{1}{1-z}=1+z+z^3+z^4+...[/tex]
for |z|<1.
You CAN find the taylor series of f(z) by taking derivatives and putting z=0, as you said. But the easy way is the use the geometric sum formula 1/(1-u)=1+u+u^2+... What should u be?
Hey guys,
Thanks for your help, but I'm still confused. I have found f(z) = 1/(z+i)(z-i) and I think I've found the partial fractions representation:
f(z) = 1/2i(z-i) - 1/2i(z+i)
but don't know where to go from here... do I separately apply taylor series expansion to each of these fractions...?
nugget said:
Hey guys,
Yes, that's the idea. Let me do an example
[tex]\frac{1}{z-2} = -\frac{1}{2-z} = -\frac{1}{2}\frac{1}{1-\frac{z}{2}} = -\frac{1}{2}\sum_{n=0}^{+\infty} {\left(\frac{z}{2}\right)^2}[/tex]
This is how to find the Laurent/Taylor series of [itex]\frac{1}{z-2}[/itex]. Can you do the same for your two dractions?
I got part a)
I'm fairly confident that the answer is f(z) = ([itex]\frac{1}{2}[/itex])0[itex]\sum[/itex][itex]\infty[/itex] ((zj) + (-z)j)/(ij)
(sum from 0 to infinity)
But don't understand how to do laurent series... I think I need to do it for the annulus centered at the origin with radius 1, and then again for the annulus centered at the origin but with arbitrarily large outer radius and inner radius of 1...
Do I need to change the format of this sum? split it into two parts? take out the first few terms? any ideas would be great!
  • · Replies 22 ·
