Complex Conjugates: I'm Not Sure Why V^2?
  • Thread starter Thread starter jeff1evesque
    Complex
The discussion clarifies the relationship between the modulus of a complex number and its components. It explains that the equality VV* = |V|^2 holds true because it represents the sum of the squares of the real and imaginary parts. The confusion arises when attempting to equate V^2 with V_r^2 + V_i^2, as V^2 includes an additional term, 2iab, from the expansion. The modulus is defined as the length of the vector in the complex plane, aligning with the Pythagorean theorem. Thus, while |V|^2 equals V_r^2 + V_i^2, V^2 is not directly equal to this sum.
jeff1evesque
Statement:
VV* = (V_r + jV_i)(V_r - jV_i) = V_{r}^{2} + V_{i}^{2} = |V|^{2}Question:
I am not sure why the second equality isn't written as, V_{r}^{2} + V_{i}^{2} = V^{2}?
Well no. Let's try V = a + ib and square it to see what happens.
V^2 = VV = (a + ib)(a + ib) = a^2 + aib + iba + (ib)^2 = a^2 + 2iab - b^2
Notice the extra 2iab term.
The modulus of a complex number is the length of the "vector" in the 2-d complex plane. Such vectors have x-component equal to the real part and y-component equal to the imaginary part. So, according to the Pythagorean theorem, they have modulus sqrt(a^2 + b^2). Squaring this gives the desired a^2 + b^2.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
