How to Calculate Strain and Dimensional Changes in Complex Loading Systems
  • Thread starter Thread starter smiffy66
    Complex Systems
The discussion focuses on calculating strain and dimensional changes in two different loading systems: a rectangular cross-section bar and a circular cross-section bar, both subjected to a tensile load of 210kN. Key calculations include determining axial strain, lateral strain, and changes in cross-sectional dimensions for the rectangular bar, and extension and decrease in diameter for the circular bar, using a modulus of elasticity of 80GPa and Poisson's ratio of 0.25. The relationship between lateral and axial strain is highlighted, emphasizing the significance of Poisson's ratio in these calculations. Additional resources are provided to aid understanding of elastic modulus and Poisson's ratio. Overall, the discussion aims to clarify these concepts for better comprehension of the homework assignment.
smiffy66
I missed a day at college last week when i was off sick due to tonsilitis. I received some homework today and it is going to be similar to a test next week. I really need to know how to do this and the lecturer has not been very helpful either.
A) I have a rectangular cross-section bar that is, 100mm x 40mm square and 500mm long. This is subjected to an axial tensile load of 210kN.
From this information i need to determine.
1) The axial strain.
2) The lateral strain.
3) The changes in cross sectional dimensions.
The material has a modulus of elasticity 80GPa, and poissons ratio of 0.25.
B) A bar of circular cross-section is subjected to a tensile load of 210kN, which is within the elastic range. The bar is made from a steel with 80GPa and Poissons ration = 0.25, it has a diameter of 25mm and 0.8m long. Determine the extension of the bar and the decrease in diameter..
Please give me as much help as you can as i am finding this very confusing, all help is appreciated.
Also:
The lateral strain at any point in a bar is usually proportional to the axial strain at the same point if the material is linearly elastic, and the ratio of the lateral strain to the axial strain is known as Poisson's ratio (n).
http://www.me.cmu.edu/academics/courses/NSF_Edu_Proj/StrAnalysis_ANSYS/pb1_part1_8.html
Thanks for the help, i should be able to make an attempt now at least. :)
