Column Loading Analysis: Strain and Stress Graph for Tubular Support
  • Thread starter Thread starter oxon88
    Complex Systems
A tubular column with a strain gauge measures load, with calculations for force, normal stress, and strain provided for loads between 0 and 500 kg. The discussion includes corrections on sign conventions for stress and strain, emphasizing that compressive stresses are negative while transverse strains should be positive. Participants explore how changing the strain gauge orientation to vertical or at a 45° angle could affect strain measurements, with suggestions for maximizing sensitivity using a Wheatstone bridge configuration. The final calculations for changes in diameter and length are confirmed as reasonable, and participants share graphs illustrating strain against applied load for different gauge orientations. Overall, the thread addresses both theoretical calculations and practical applications of strain gauges in structural analysis.
oxon88
A tubular column supports a mass as shown in the diagram below. A
strain gauge is placed transversely on the outside diameter of the bar to
act as a load measuring device.
The column has an outside diameter of 50 mm and an inside diameter of
40 mm. The modulus of elasticity of the tube material is 250 GN m–2 and
the poison’s ratio is 0.33.
Q. Sketch a graph of the expected strain against the applied load, for a
load range from 0 to 500 kg. Make load the horizontal axis on the
graph and strain the vertical axis.
Force,N = M.G
Area,A = ∏/4 . (Do2 - Di2) = ∏/4 (0.05m2) - (0.04m2) = 7.0685834 x10-4 m2
Normal Stress, σ = F / A
Normal Strain, ε = deformation in length / Original Length = l - l0 / l0
Young's Modulus, E = σ / ε = 250 GN m–2 = 250x10-9 N m-2
ε = σ / E
Poisson's Ration, V = 0.33
Transversal Strain, εt = -νε
Calculate Force, N, for range 0kg to 500kg using using F=MG
Calculate Normal Stress for the range 0kg to 500kg using σ = F/A
Calculate Normal Strain for the range 0kg to 500kg using ε = σ / E
Calculate Transverse Strain for the range 0kg to 500kg using εt = -νε
Plot a graph using Transverse Strain εt Vs Force, N
Does this look anywhere near correct?
Anyone?
E should be 250*10^9 N/m^2
ok so i had another go, changing the modulus of elasticity. The graph looks much the same as before.
Does this look correct?
Please show us your numbers for 500 kg. Also, aren't you asked to plot the transverse strain, rather than the axial strain? Also, the axial strains are negative, and the transverse strains are positive.
Load(Kg) | Load (N) | Normal Stress | Normal Strain | transverse strain | longitudinal strain
100kg | 981N | 1387831.118 | 5.55132E-06 | 1.83194E-06 | -5.55132E-06
200kg | 1962N | 2775662.235 | 1.11026E-05 | 3.66387E-06 | -1.11026E-05
300kg | 2943N | 4163493.353 | 1.6654E-05 | 5.49581E-06 | -1.6654E-05
400kg | 3924N | 5551324.47 | 2.22053E-05 | 7.32775E-06 | -2.22053E-05
500kg | 4905N | 6939155.588 | 2.77566E-05 | 9.15969E-06 | -2.77566E-05​
here are my numbers for 100Kg to 500Kg. apologies for the formatting.
Graph looks like this
I spot checked your numbers, and they look good. What sign convention do you use for stress; is compressive stress regarded as positive or negative?
Stresses that result in extension, or tensile stresses, are defined as positive, and
compressive stresses as negative in sign.
If this is the case, then the normal stresses in your table should be negative, and the normal strains should be the same as the longitudinal strains.
ok I've had a rethink and changed the table. I'm a little confused as I believe the transverse strains should be positive in value. however it is showing as negative.
-100 | -981 | -1387831.118 | -5.55132E-06 | -1.83194E-06 | -5.55132E-06
-200 | -1962 | -2775662.235 | -1.11026E-05 | -3.66387E-06 | -1.11026E-05
-300 | -2943 | -4163493.353 | -1.6654E-05 | -5.49581E-06 | -1.6654E-05
-400 | -3924 | -5551324.47 | -2.22053E-05 | -7.32775E-06 | -2.22053E-05
-500 | -4905 | -6939155.588 | -2.77566E-05 | -9.15969E-06 | -2.77566E-05
The transverse strain should be opposite in sign to the longitudinal strain. If the cylinder compresses axially, it must expand in the radial and circumferential directions. That's what your Poisson Ratio equation says.
Chet
ok. So i changed the signs. I now have these figures and the graph is below. Does this now look ok?
Load(Kg)| Load(N) | Normal Stress | Normal Strain | Transverse Strain | Longitudinal Strain
100 | 0981 | -1387831.118 | -5.55132E-06 | 1.83194E-06 | -5.55132E-06
200 | 1962 | -2775662.235 | -1.11026E-05 | 3.66387E-06 | -1.11026E-05
300 | 2943 | -4163493.353 | -1.66540E-05 | 5.49581E-06 | -1.6654E-05
400 | 3924 | -5551324.470 | -2.22053E-05 | 7.32775E-06 | -2.22053E-05
500 | 4905 | -6939155.588 | -2.77566E-05 | 9.15969E-06 | -2.77566E-05
Looks good.
Chet
Great Thank you. The next part to the question has me a bit confused.
Show with the aid of a diagram how the orientation of the strain gauge could be changed to provide a greater strain for the same load. Sketch a graph of strain against applied load when the strain gauge is in
the new position.
I'm thinking that maybe the strain gauge could be mounted at a 45° angle. But would this give greater strain for the same load? Or am I over thinking this and should it just be mounted vertically?
the new position.
Have you learned how to express the strain in an arbitrary direction in terms of the components of strain in the principal directions? Is the question asking about the absolute magnitude of the strain in an arbitrary direction (i.e., irrespective of its sign) or about the actual strain in an arbitrary direction? I can see why you are confused.
I have nothing in my learning material that details anything like that.
here is the question:
Well, OK, if you're talking about the absolute magnitude of the strain, and not whether it is extensional or compressive, then you can mount the strain gage in the vertical direction. That will give you the maximum absolute magnitude. However, if you're including the sign of the strain, the maximum value of strain is in the circumferential direction.
Likes 1 person
Many Thanks. You are a great help :)
the next part of the question asks to Calculate the change in:
(i) the outside diameter (Do)
(ii) the inside diameter (Di)
(iii) the column length (l)I have got the following answers:
(i) = 0.000457984 mm
(ii) = 0.000366387 mm
(iii) = -0.005551324 mm
do these answers look reasonable?
I think these are correct for the data given.
Oxon88 could you upload the workings, answers and diagrams for parts b and c please so I can have look over them...
Anyone got an image of the graph of strain against applied load when the strain gauge is in
the new position and have any info or useful links to info on strain gauges
Still looking for help with the strain gauges. I guess if the gauge was rotated 45 degress it would then measure the axial strain and from those numbers posted earlier they would become positive and you would construct a graph from them would that be correct?...
hey. can you post which questions you are wanting the workings for?
btw, for the new strain gauge position. You want to look at mounting the vertical axis.
Many thanks, I am struggling to find good information I understand for the questions below and any help gratefully received
question 1; Show with the aid of a diagram how the orientation of the strain
question2; Sketch a graph of strain against applied load when the strain gauge is in
the new position
question 3; show how four strain gauges can be used in
conjunction with a Wheatstone bridge to give maximum sensitivity
of the load measurement system.With the aid of sketches show how four strain gauges can be used in
of the load measurement system. Show clearly the orientation of the
strain gauges on the tubular column and the positioning of these
gauges on the Wheatstone bridge
ok so first question. you should be looking to mount the strain gauge in the Y axis, (ie vertically) this will allow for greater sensitivity as the load is being applied in the Y axis. simply redraw the diagram but change the strain gauge position to vertical.
Thought that and done that so relieved that is correct. Now from doing that and the data earlier contruct a graph with the axial strain values, would this be correct for question 2?? If it is my graph is a wavy line...
the graph should be a straight line. it should look the same as the first graph.
you should first calculate the normal stress
then calculate normal strain
from normal strain you can calculate the Transverse Strain
then from the Transverse Strain, calculate the Longitudinal Strain
ok many thanks do you have values for these so I know what I am actually looking to get from my calculations??
Any help on the last part?...
  • #31
post #13 has the correct figures.
  • #32
Thanks, and this part...
  • #33
take a look here: http://www.omega.com/faq/pressure/pdf/positioning.pdf
for this question, i explained how the circuit works and what the benefit is using the wheatstone bridge circuit. look at figure D in particular for the positioning of the strain gauges.
  • #34
quick couple of questions and many thanks so far.
Have you had this all marked??
Also the table in post#13 are the same values I had calculated for the graph of the expected strain against the applied load. How do these work then for the graph of strain against applied load when the strain gauge is in
the new position?? Just a bit confused?
  • #35
yes it has been marked as correct. I achieved distinction grade.
for the first graph, it wil be Transverse Strain Vs Load
for the second, it will be Longitudinal Strain Vs Load
  • #36
Magic Oxon88 and well done some of these questions are tough to say the least. I will keep working away and try and get it all done. Many thanks for your help. Hopefully in the future I will be able to repay the favour...
  • #37
Oxon could you upload the Longitudinal Strain Vs Load graph please
  • #38
  • #39
Thanks Oxon88 for your great help
  • #40
Your graph Oxon what have you used for the x axis?
