Complex numbers (5+2i)=SQRT(x+iy)
To evaluate the equation (5+2i)=SQRT(x+iy), raising both sides to the power of 2 is suggested, leading to 21 = x + iy, which indicates no imaginary part in the solution. However, it is clarified that (5 + 2i)^2 does not equal 5^2 + (2i)^2, as the correct expansion includes both real and imaginary components. The discussion also touches on the potential of using polar form for further evaluation, with participants confirming that this method works effectively. Overall, the conversation emphasizes the importance of correctly handling complex number operations. The insights shared can aid in understanding complex number equations better.
johnwalton84
How do you evaluate this type of problem:
(5+2i)=SQRT(x+iy)
Mathematics news on Phys.org
Have you considered raising both sides to the power of 2? Or writing both sides in polar form?
Yes, but when you do that the i value on the left disappears and you get
21 = x+iy
which suggests that there is no imaginary part of the solution (?)
I haven't tried writing both sides in polar form, i'll try that now
21 = x+iy
No, since (5 + 2i)^2 is NOT equal to 5^2 + (2i)^2.
(5 + 2i)^2 = (5 + 2i)(5 + 2i) = 5*5 + 5*2i + 2i*5 + 2i*2i = 25 + 10i + 10i - 4, etc.
:blushing: of course :blushing:
:smile: thanks
it works fine in polars as well
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
10K
