Confirm a) & Solve b): Homework Help
  • Thread starter Thread starter battery2004
    Homework
The discussion focuses on confirming the correctness of part (a) of a homework problem related to complex numbers and roots. It is clarified that the initial answer provided for part (a) is incorrect due to a misunderstanding of the question. The correct approach involves using polar form for complex numbers before calculating the roots. The explanation includes the method for finding the fourth roots of a complex number, specifically 7i, using the polar representation. The thread emphasizes the importance of proper conversion and calculation steps in solving complex number problems.
battery2004
http://img139.imageshack.us/img139/999/ksknl6.th.jpg http://g.imageshack.us/thpix.php
Could someone confirm that the a) part is correct, and if it is, then what is the next step? :)
And I am not exactly sure what to do in the b) part.
I would really appreciate if someone could help me out with this. :)
Thanks in advance.
NO, (a) is not correct because you haven't answered the question! I think you have misunderstood what is asked. If you were asked to find ^4\sqrt{16}, you wouldn't answer "161/4"!
Don't change from polar to rectangular form until after you have done the root! One important reason for using polar form for complex numbers is the fact that
[r (cos(\theta)+ i sin(\theta)]^n= r^n(cos(n\theta)+ i sin(n\theta))
For n= 1/4,
(7(cos(\pi/2)+ i sin(\pi/2))^{1/4}= 7^{1/4}(cos(\pi/8)+ i sin(\pi/8))
Also, since adding 2\pi to the argument doesn't change the complex number, and 2\pi/4= \pi/2 another fourth root is
7^{1/4}(cos(\pi/4+ \pi/2)+ i sin(\pi/4+ \pi/2))
yet another is
7^{1/4}(cos(\pi/4+ \pi)+ i sin(\pi/4+ \pi))
and, finally,
7^{1/4}(coS(\pi/4+ 3\pi/2)+ i sin(\pi/4+ 3\pi/2))
Those are the four fourth roots of 7(cos(\pi/2)+ i sin(\pi/2))= 7i
Edit: Shows what I know. Listen to HallsofIvy instead
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
