Composition of functions domains
The domain of the composition of functions f(g(x)) is not simply the intersection of the domains of f(x) and g(x). Instead, it depends on whether the range of g is contained within the domain of f. If the range of g falls outside the domain of f, it restricts the domain of f(g(x)). Therefore, the actual domain of f(g(x)) is the subset of g's domain where g(x) is valid for f(x). Understanding these relationships is crucial for correctly determining the domain of composed functions.
bcheero
Is it always true that the domain of f(g(x)) is the intersection of the domains of f(x) and g(x)?
I've been having trouble with this and this answer would make me fully understand this concept.
Thanks to everyone!
Mathematics news on Phys.org
It depends on the range of g. If the range of g is contained within the domain of f, then the domain of g is the domain of f(g(x)). If the range of g is not contained, then the part of the range outside is cutoff, inducing a cutoff in the useful domain of of g, i.e. that which ends up as the domain of f(g(x))
Thanks to everyone!
No, it is not always true. In fact it is seldom true. What is true is that the domain of f(g(x)) is that subset of the domain of g such that g(x) is in the domain of f(x).
The domain is simply the set of values your function can accept as input.
The function f o g has the same domain as g which we can pretty safely assume to be all the real numbers.
The domain of f might be more narrow, but f o g has the same domain as g.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
