Comprehensive electromagnetic induction question
The magnetic field between the poles of an electromagnet is 2.6 T, and a coil with a resistance of 25 ohms, radius of 1.9 cm, and length of 15.0 cm is placed in this field. When the current supply is turned off, a total charge of 7.0 mC flows through the coil. The discussion emphasizes the need to understand the relationships between charge, current, induced emf, and magnetic flux changes to solve for the number of turns in the coil. The initial approach using certain equations was deemed inappropriate, suggesting a need for a more comprehensive understanding of electromagnetic induction principles. The conversation concludes with an acknowledgment of the need for further exploration of the relevant equations and relationships.
adrianx
The magnetic field between the poles of an electromagnet is 2.6 T. A coil of wire is placed in this region so that the field is parallel to the axis of the coil. The coil has electrical resistance 25 , radius 1.9 cm, and length 15.0 cm. When the current supply to the electromagnet is shut off, the total charge that flows through the coil is 7.0 mC. How many turns are there in the coil?
I know that I have to use more than one equation but I've searched through my book for a couple hours now and nothing is helping. So far, I've picked up these equations:
I = (epsilon)/R = vBL/R
(epsilon) = -L (deltaI / deltat)
L = (mu0) n^2 (pi) r^2 l
flux = LI = (mu0) N I (pi) r^2
I tried to combine the equation for epsilon and self inductance (L) and came out with the wrong answers of 3.42E5 and 5.13E4. Ridiculously large numbers I'm sure. I would appreciate any insight =)
Actually, none of the four equations you chose are really appropriate for this problem. To get an idea of which equations you should look for (if you can't remember them), consider the following detailed description of what is physically going on here:
As the magnetic field produced by the electromagnet decreases from 2.6 T to zero, the magnetic flux through the coil decreases from some initial value, to zero. This change in flux induces an emf in the coil, which in turn causes a current in the coil. The net effect of this current, during the time it takes for the magnetic field to decrease to zero, is to cause a total of 7 mC of charge to flow through the coil.
From this description, I hope you can see that you need to know or find out the following relationships, and put them together:
1. How is the total charge that flows through the coil, related to the current through the coil?
2. How is the current through the coil related to the emf in the coil?
3. How is the emf induced in the coil related to the change in the magnetic flux through the coil?
4. What are the initial and final values of the magnetic flux through the coil?
You may need to introduce one or two other variables along the way, of course.
got it.. thanks a lot!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
